Thread: Refitting cross member tips and hints wanted.
    May 2015
    Williamstown, Victoria
    I have had a go at refitting the cross member, as usual there is not a lot of room there. If you managed to spread the chassis rails with a jack, how did you do this? a section of 2x4? Where did you place the jack and the wood. The best place seems to be where the radius arm is bolted on I had a go there and the wood, was pushed downwards, away from the body.
    Any ideas or suggestions welcome.
    Build date 11th Oct 2003
    LROCV #1410
    Normanhurst, NSW
    Have you tried using wedges instead of a jack?
    Easier to position than a jack,
    Roger
    Sep 2010
    The Hills.
    152.79 MB
    Beg, borrow, steal or hire a porta power.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jun 2013
    Universe A
    Quote Originally Posted by Bohica View Post
    If you get a standard hydraulic bottle jack, pop out the oil fill plug, and overfill it laying on its side.. Then it will Jack out to full extension while laying horizontal.
    It will need returning to the proper level afterwards.
    You will be able to use anything of closely appropriate length to extend the rest of the way across.
    I've never really had any issues at all tbh, but if you had to expand the width, that's how you can do it.
    Pipe, wood etc etc, should be fine as long as of reasonable strength.
    May 2009
    Tatura, Vic
    It has been a long time since I have done it, so don't remember exactly where I used it, but I did use a bottle jack and a piece of wood cut to length.
    I would have placed it as close as practical to where the cross piece goes.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
