 Originally Posted by
oldie
				Just replaced aftermarket reverse light on my MY2010 Puma trayback. And now the reverse and brake lights are not working. Are they related or is it a coincidence.
Checked fuses. After initial install of new lamp only had 7.7 volt on reverse power lead at the back. Now 0 volts. Because it is c/chas trayback from factory, rear wiring is not plug and play, but it all worked fine until my intervention yesterday.
I have wriggled connector on gearbox reverse switch for no joy. Reverse lights work if disconnected from main loom and external power applied.
Tail lights and blinkers work fine so earth is good.
So I had a look at stop light switch. There are 2 on the bracket. Why ? Is there something tricky here ? Don't want to cause any more problems.
Where to look next ?
Oldie
 Did you use led replacements? If so then polarity is important.
				JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto:                Tins
1994 D1 300TDi Manual:        Dave
1980 SIII Petrol Tray:             Doris
OKApotamus #74
Nanocom, D2 TD5 only.
