Results 1 to 10 of 12
Thread: Fuel leak
    Apr 2010
    sydney
    Fuel leak
    Hi guys, I have a significant fuel leak in my 2011 D4 2.7. It's dripping from the fuel tank and cross-members. I changed the filter recently, so that is the likely culprit. It was an aftermarket one.
    I pulled the filter off. there is no fuel above the housing, so it seems as if it is coming from the filter to bousing connection. It screws on and off ok and seems to click into place properly, but I am out of ideas.
    There is no o-ring that goes on top of the filter is there? The o-rings that come with the kit go on the bottom where the water sensor is, but as far as I can tell, there is no o-ring for the top, the filter just screws straight onto the housing.
    Any ideas?
    Lucas
    Oct 2012
    Fuel leak
    The filter engages with the teeth on the outside and by rotating 45 degrees it clamps into the housing. There is no external o ring.
    The good filters show you the lock and unlock position on the filter. There’s an arrow on the plastic body you line up with. A bit fiddly to line up but super secure when done properly.
    Jan 2014
    Perth Western Australia
    if its a cooper branded filter it will likely leak. Over the years I have tried different brands and the only one that fits properly is the genuine filters.
    Also in the top of the filter is a rubber type oring that can randomly pop off and get left behind in the filter housing, make sure there isnt one in the top housing inside the tube.
    Daz
    Quote Originally Posted by DazzaTD5 View Post
    That is what I have found as well - only use genuine. Also overtightening the sensor on the bottom of the filter can cause a small crack in the plastic with a resulting drip, drip, drip. Of note the price of a genuine sensor by itself is about the same as buying a genuine filter kit, which includes filter mount/bracket, new filter and the sensor.
    Oct 2012
    The Ryco ones available from Repco are excellent quality to my eye.
    Apr 2010
    sydney
    Is it possible the leak could be coming from somewhere else? There is fuel on top of the fuel tank bash plate that is gradually leaking out as I drive around. I haven't done any damage or serious offroaading lately.
    Do you park on a slope?
    Do you fill to the top?
    My Def weeps when near full parked on a f-r slope.
    There is a fault in the joint on top of the tank.
    When down by 15 litres or so, all is fine.
    Apr 2010
    sydney
    Thanks for your help guys. I've cleaned everything up and driven around and had another look at it and it is definitely leaking between the housing and the filter. It's a Ryco filter. It seems to lock on ok, but I guss the tip rubber seal isn't that great.
    I've ordered a new genuine housing and filter, so hopefully it arrives before the weekend when I am supposed to go to Fraser island. Cheers
    Apr 2010
    sydney
    Update
    Just an update - I went to a great auto parts place that had 3 fuel filters for the car:
    Ryco Z1116
    Cooper WCF249
    Mann WK8022X
    The guy said they had a note on the system saying the Ryco was better than the Cooper. However, he thought the Mann was probably the OE one for the Landrover and was just rebranded by LR. The instructions and marks on the filter looked the same as the OE LR one. Mann Filter much more expensive than the others.
    I don't have a water sensor on my fuel filter at the moment (not sure when my mechanic didn't put it back on?) so can only comment on the top rubber seal. The Mann Filter and Cooper seemed to have the same top rubber seal, whereas the Ryco looked a little different and probably "shorter".
    Anyway, I bought a Mann one. It was a little harder/tighter to get on than the Ryco one, so hopefully will seal better. I will see if it leaks over the next few days. I'd be tempted to try the Cooper one as it seemed to have the same top seal as the Mann one, but it didn't look as well put together.
    Lucas
    Apr 2012
    Whyalla, SA
    Glad you’ve solved your issue
    I’ve been using Ryco now (in stock local) and no issues at all.
    I’ve used Ryco air oil and fuel filters for a while on all the LRs and no detriment.
