Results 1 to 10 of 20
Thread: Ground points for charging / jump starting
    Jun 2018
    Tamworth
    Hey team. I've had a good google/forum search but for the life of me I can't find a clear answer even though I know it's probably obvious.
    This morning in the cold my D3 wouldn't turn over. Battery around 5 years old probably on the way out. I've gone and got a battery charger but for the life of me I can't find a good point I'd like to charge / jump start off.
    Can someone please send through a photo of where they connect their black leads to?
    P. S. I'm running a traxide system and my old man was telling me to just use jumper cables on the auxiliary battery. This is dangerous right?
    Mar 2016
    Adelaide
    Is there a reason why you can’t connect your cables up to the red and black on your main battery?
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    St Helena,Melbourne
    4.28 MB
    Charge the battery off the terminals, when jumping earth off the body/chassis - there are 2-3 earth studs to the right of the battery compartment on the inner guard.
    I have charged off the aux battery before without issue but now use the anderson plug i fitted on the rear bar.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    Adelaide
    Why not jump it from the terminals also?
    Jun 2018
    Tamworth
    These ones?
    Jun 2018
    Tamworth
    Quote Originally Posted by John_D4 View Post
    I've always been told you risk the battery exploding. This seems to be the consensus online
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Parso View Post
    These ones?
    That's the ones.
    1974 VW Kombi bus
    St Helena,Melbourne
    4.28 MB
    The inrush of current can fry the electric modules, this is true of all EFI/modern vehicles.
    1974 VW Kombi bus
    Brisbane,some of the time.
    Has the vehicle got a handbook,if so have a read,or someone else may have the book.
    If not,charge off terminals,to jump start use positive and a good earth for the negative.
    Jun 2018
    Tamworth
    That's the question Scarry. Where is the good earth? Book doesn't say
