Results 1 to 10 of 22
Thread: Fuse or Circuit Breaker
    May 2009
    Tatura, Vic
    I have an auxiliary battery mounted at the rear of my D2.
    From this battery I am going to run 6B&S cable to an Anderson plug at the rear bumper to charge the house batteries in my Tvan.
    What is better to use, Maxi fuse or circuit breaker and the reason for your choice.
    Also opinions as to size. I was thinking 100 amp.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Sep 2010
    Moe, Victoria
    I'll be interested in the advice you get to this too. For interest, in a recent youtube video MOST PEOPLE GET THIS WRONG - YouTube, Ronny Dahl essentially said to preference fuses in engine bay due to heat, and circuit breakers elsewhere. I have no idea if the advice is based on any expertise.
    Quote Originally Posted by d2dave View Post
    Aug 2010
    Sunbury, VIC
    I would use fuses myself for 2 reasons. Firstly is the heat issue under the bonnet. Circuit breakers rely on a thermal circuit that heats up as load increases and excess heat can cause early tripping. The other reason is vibration - eventually this will cause the breaker to nuisance trip - it’s one of the reasons we run HRC fuses in our gensets on pretty much all circuits, even low voltage, low current DC.
    Sep 2010
    The Hills.
    152.79 MB
    What Gav said.
    As for rating, the cable you are using is rated to a max of 120. I'd prefer a little more margin than 24% but it's probably ample given good cable performs better than it's stated rating.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Brisbane,some of the time.
    Quote Originally Posted by Homestar View Post
    On another note,we have HRC fuses on many jobs as well,they are often near impossible to get hold of these days,particularly if they are needed urgently.
    My two cents on what the OP asked,fuses any day.
    May 2009
    Tatura, Vic
    Gav. Heat is not an issue here as the wiring is going from my battery in the rear of the vehicle to rear bumper.
    However, in response to your heat concern with circuit breakers, I have one of Tim's Traxide isolators.
    He told me that due to my battery being in the rear that I need a circuit breaker at each battery in case of a short between the two.
    He sold me two 50 amp auto reset breakers with the isolator. They have been in use now for 10 plus years without a problem, one under the bonnet, one at the rear.
    And when it comes to this stuff Tim is the man.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Queensland
    Hi Dave and you can use circuit breakers or fuses and don’t take any notice of the idiot misinformation in that video.
    I near burst out laughing when I heard him say “You should not use circuit breakers under the bonnet because of the heat, but fuses will work”.
    Yes, in extreme heat situations, circuit breakers will go open circuit at lower currents.
    BUT GUESS WHAT, fuses will act in the exact same manner. He has no idea what he is talking about.
    Dave, if you use 6B&S cabling, while 6B&S is rated at a continuous current 140 amps in “OPEN AIR”.
    But in the confines of a motor vehicle, 6B&S is derated to a continuous current rating of 105 amps.
    Any fuse or circuit breaker use to protect a circuit must have a maximum current rate of at least 20% less than the cables continuous current rating, so an 80 amp fuse or circuit breaker would be perfect.
    Queensland
    Yep, fuses are far more tolerant to vibration.
    Queensland
    Quote Originally Posted by towe0609 View Post
    Hi towe0609, and sorry mate but that guy is nothing more than a keyboard cowboy.
    There are so many erroneous statements in that video that people would be far better off ignoring just about everything he rants on about.
    The most common bit of B/S that shows he knows nothing about batteries, is his claim that taking AGMs below 50% SoC can damage them.
    Why would battery manufacturers specifically state that their AGM batteries can be discharged down to 20% SoC and some of the newer AGMs can be safely discharged down to 0% SoC?
    Again, he calls the AUXILIARY battery a house battery.
    For the forty plus years I have worked in the field, the second battery in any vehicle has always been called the Auxiliary battery and House batteries are found in Camper Trailers, Caravans and Motorhomes.
    He as done a little bit of googling and is now making out he is some sort of expert in a field he actually hasn't got a clue about.
    Again, he states the second battery under the bonnet should be a Deep Cycle battery and he claims it can used to jump start and assist when winching.
    First off, most Deep Cycle batteries do not like under bonnet heat and they do not tolerate any form of ultra high current discharging.
    There are heaps of other errors in his video.
    Apr 2016
    Country Vic.
    I have both. In engine bay of the D1.
    Both batts in engine bay. Aux has a 50A breaker, main has a 100A maxi.
    Never triggered/tripped/blown.
    Have accidentally hit neg to pos on the main a couple of times doing work, usually spanner(never learn!). Nothing tripped or blown.
    I personally prefer a breaker simply for the quick and easy reset.
    If there is a major issue and trips again, you don't end up blowing another fuse again .. just another reset. if happens again then figure out what/why, rectify, and away you go.
    But with a fuse, if tripped a second time, do we really carry multiple 100A maxi fuses with us all the time, and where do you get one again easily enough .. especially when remote?
    For d2dave, have you already installed an fuse/breaker to the aux battery? Is the question just related to how to fuse aux to the van?
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
