Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 136
Thread: Thought i had joined the broken crank club but NO!
    Jan 2020
    McGowanastan
    Gday All
    90km/h towing the van , felt a slight jerk then oil light comes on and the dash starts lighting up and the engine dies..
    Tried a quick start but didnt fire so called the tilt tray.
    Only codes that stand out is cam sensor out of range or something to that effect..others are just a flow on i think.. fuel rail press low , plus loss of comms to suspension etc
    So a quick question... whats the easiest way to check for broken crank ? Cant see rocker gear from oil filler from what i can see..
    Car has been meticulously maintained , belts done at 160k and upgraded oil pump as well.. oil every 10,000 or 6 months so would be surprised if its broken timing belt or hpfp belt..car is at 213k km. Is 2008 tdv6..
    Any suggestions on what to check appreciated..
    Cheers Bulletman
    Mar 2016
    Think i joined the broken crank club today
    So sorry to hear buddy
    Cam sensor out of range would imply the crank isn’t in time with the cam (crank sensor and cam sensor out of sync, which might tell me the front and back of the crank aren’t joined at the hip anymore. There could be other causes, but I think you’re right.
    2007 Audi RS4 (B7)
    Jan 2020
    McGowanastan
    Quote Originally Posted by DiscoJeffster View Post
    Joys of the tdv6 engine.. dont work on tuesday so will make a start and see whats what...
    just a bit annoyed we just spent 8k getting a gearbox and torque converter recon..
    Cheers Bulletman
    Mar 2016
    Quote Originally Posted by Bulletman View Post
    Cheers Bulletman
    What engine is it?
    2007 Audi RS4 (B7)
    Jan 2020
    McGowanastan
    What engine is it?
    2.7 tdv6 @ 213,000 ks
    Oct 2012
    Great sadness but at least Terry engines are available for a swap.
    Jan 2020
    McGowanastan
    Quote Originally Posted by PerthDisco View Post
    Yes is an option ... but with how cheap these are advertised now its line ball if worth putting more $$ into it or part it out and say goodbye to LR ownership..
    Will see what i find tuesday then look at pros and cons of an engine swap .. capable of doing the swap myself but will need to read up on it then try and find a engine that the wreckers havent put the LR tax on ..
    Fun times ahead.
    Cheers bulletman
    Oct 2012
    Fun times ahead.
    Cheers bulletman
    Happy to help.
    Jan 2020
    McGowanastan
    Happy to help.
    Thanks for the offer.. will see what tuesday brings and go from there... but im prepared for worse case scenario..
    Cheers Bulletman
    Noting that the 2.7 does not tend to break cranks like the 3.0 but it is not unknown - you might be lucky - I hope so.
