Thread: Unlock flashes
    Mar 2018
    Perth (near Malaga)
    Unlock flashes
    Normally when I unlock the D3 I get one long flash on the indicators. Today I got 5 (or 7 but I think it was five) rapid flashes. I pushed unlock again and got the same thing. Lock gave the three flashes and the next unlock gave the normal single flash.
    I can find no reference to this behaviour in the manual or anywhere within my google-fu. Anyone have any ideas?
    May 2014
    Point Cook, VIC
    Unlock flashes
    8 rapid flashes when unlocking means the alarm was activated since last armed.
    If the alarm goes off whilst you are away it resets after 30s, so this way you know it was activated for some reason.
    Bonnet not fully latched closed the most likely reason. Mine used to activate in strong winds due to the bonnet moving.
    Edit: and yes - it is in the owners manual under Locks & Alarms.
    Oct 2016
    Perth, AU
    Or, the bonnet is just fine, but the bonnet switch is failing… Common failure.
    If this is the first time you’ve seen it, may not be anything to worry about?
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    May 2014
    Point Cook, VIC
    Or someone tried to force open the bonnet…..
    Jan 2010
    It is also worth checking the doors are actually locking, I had the driver's door lock fail once but I didn't realise until one day I pulled the door open while the car was "locked" setting off the alarm.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
