Thread: Installing a bigger HD..
    May 2003
    On The Road
    This laptop has two M.2 nvme drives, both 2TB.
    How do I swap one for a 4TB ?
    The M.2 drive with windows 11 is spilt with C Drive being 100gb and the rest as F drive.
    I really wouldnt mind a fresh win 11 install but-- windows tells me its gunna delete stuff from the other two drives to do this.. which is-- strange??
    Aug 2018
    Bendigo
    I'd use Hirens Download | Hiren's BootCD PE to copy over the the boot drive, it has a few copy tools to try. You can then create partitions if you want and copy the rest of the data. You'll need a caddy or some other way to have all the drives attached.
    May 2003
    On The Road
    This looks ok?
    can use it later as a 4tb storage drive
    Startech Dual M.2 SATA Enclosure - RAID - USB 3.1 Gen 2 USB C / USB A | PLE Computers
    Feb 2010
    I mirrored my drive using Acronis true image. Other options can do it as well. Mirror go on bigger drive then simply insert new HD and remove old one.
    Aug 2018
    Bendigo
    That would do the trick. I have one like this I use at work.
    ORICO SuperSpeed USB3.0 SATA Hard Drive Docking Station | Orico HDD Docking Bays & USB Hubs | 6619US3-BK
