As above. The gauze is soft soldered on to the brass tube in mine, Soldering a brass extension on would not be an issue. Do not fail to use the gauze unless you can guarantee that all fuel put into the tank is clean for the life of the vehicle.As mentioned above, rust, flakes of paint from inside a jerrican, crud out of a bowser, or the dirt that dropped in when you took the fuel cap off will eventually build up  enough to block the screen in the fuel pump.
And end the pipe about 10mm above the bottom of the tank - you don't really want the condensed water in your fuel system.
