Hello All,
After some more digging I found out that the combination disc and belt sanders that sit on a bench are called 'stationary sanders'. According to Empire Abrasives stationary disc sanders do require a more heavy duty disc. Accessed 9th August 2023 from Choosing the right Sanding Disc - Empire Abrasives
Empire Abrasives provide the following description .... Stationary discs sanders can usually be found configured on a pedestal, workbench or on combo belt grinder machines. These disc sanders usually require a more rugged PSA disc and range anywhere from 6” to 14” in size. Dissimilar to the other types of sanders that require you to hold the machine and apply pressure to the work-piece, the wheel with the abrasive will spin, while the user rests the work-piece in front slightly applying pressure to the wheel. The sanding discs are X-weight cloth backed.
I checked on Amazon and yes there are particular sanding discs available that are available for stationary sanders such as this Sungold product ... Sungold Abrasives 336084 120 Grit 6" X -Weight Cloth Premium Industrial Aluminum Oxide Psa Stick-On Sanding Discs For Stationary Sanders, 10 Sanding Discs/Pack : Amazon.com.au: Home Improvement
I have also contacted an Australian sandpaper specialist to see if there are any products stocked here in Australia. I will see how they work out for price compared to the Amazon suppliers.
Kind regards
Lionel
