Thread: double row alternator pulley?
    Cooroy, QLD
    I have double row pulleys on the crank and water pump but not on the alternator. Is there an off-the-shelf double row alternator pulley that will fit? I can't find a part number online, have been considering getting one machined but thought I would check here first.
    Adam
    Which military LR is it for?
    Back down the hill.
    Try MR Automotive, they were very knowledgeable and helpful when Jerry had similar issues on our Cooma sojourn.
    Cooroy, QLD
    the engine is a IIA, it's not in a military vehicle but it came out of one originally, hence the double row pulleys.
    For quite a few years now I have been running my ex-military 2a with the double pulley on the crankshaft, but single pulleys on the water pump and alternator - the inner groove on the double pulley lines up. Obviously with a single belt - the double belt is not needed unless you are using the eight blade fan, which I am not.
    Cooroy, QLD
    I have the 8 blade fan and I'd also just like to run two belts because then my OCD wont yell at me every time I open the bonnet.
    Fair enough!
