Results 1 to 8 of 8
Thread: D4 Solid Beep Park Sensors
    Feb 2010
    Question D4 Solid Beep Park Sensors
    Hoping someone might be able to help diagnose the issues with the park sensors. Have just purchase a MY16 D4 and had OL bullbar fitted. This was all done from interstate as I brought the vehicle in Vic and had it transported over to WA. Anyway after Bullbar fitted the park sensors now give a solid tone once you go into reverse or drive, hitting the button turns them off. Have checked all the wiring in the Bullbar everything in tact and there is no warning code to say there is an issue. Has anyone had the same issue? Any advice be great.
    Mar 2021
    Newcastle
    I had an ARB bar fitted last year and mine does it only after I’ve washed the car or it’s been raining, I’ve checked and can’t really see anything out of place. Once whatever is causing it is dry then they function as normal.
    Feb 2010
    Would the diagnostic tool be able to tell me what the issue is? It’s really starting to frustrate me now.
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Yes it should. I get it when I put my tow bar on.
    The diagnostic tool will be able to show live values from each sensor and you can get someone to walk around in front of them to see the values changing. It'll also log any faults if that's the issue.
    TonyC is offline Wizard Silver Subscriber
    NE Victoria
    32.83 MB
    Was the bar fitted by OL (I assume Opposite Lock)?
    I assume they have a national warranty, take it to a branch in WA and get them to fix it.
    Tony
    Nov 2018
    Hobart, Tasmania
    Quote Originally Posted by Porker View Post
    I don't have a bullbar but my sensors and reversing camera stop working when it rains.
    I get a warning beep and a message on the screen saying the camera is not working.
    Obviously the camera and sensors share the same circuit.
    When "something" dries it all starts working again.
    Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
    Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
    Oct 2013
    Old Toongabbie, Sydney NSW
    Mine's the same. I have just put up with it as it's usually only when i reverse which I suppose might indicate camera involvement too.
    Martin
    Feb 2010
    Have solved the issue with the dang senors, apparently when a Bullbar is fitted they need to be re-calibrated, had this done at our last service and has solved the problem. Who would have thought!
