Results 1 to 10 of 13
Thread: RR SDV8 Oil cooler leaking - To drive or not to drive ?
    Aug 2023
    Hoping someone can help answer my question . I have a RR L405 with SDV8 with 120K mileage . I have confirmed the oil cooler is leaking .
    The stage where the leak is up to is :
    1. I can smell burning oil smell through vents
    2. Oil leaks down back of engine.
    3. Rarely drips on the ground, mostly after long trips
    4. Can confirm there is a small amount of oil in the coolant tank
    5. Drives fine and oil level has only reduced by a small amount.
    6. Engine temperature and performance runs fine.
    I have an independent mechanic that has let me down badly with communication, oil cooler replacement was supposed to be started already but hasn't, and I have a 10 hour return trip to do in the car.
    I'm thinking if I nurse the car on the drive and keep rpms down - what are our thoughts ? has anyone ever damaged an SDV8 from a leaking oil cooler ?
    Any help on the subject is appreciated
    NSW SW Slopes
    Engine revs won't have any effect on the leak and the burnt smell will be from oil gettng onto the cross-over pipe. As there is already oil in the coolant the cooling system will have to be flushed so a little more oil won't be significant.
    The leak will be from gaskets and from a pair of o-rings on the turbo oil feed pipe that connects into the back of the oil cooler. Have a good 10-hour return trip!
    Get your mechanic to fit Viton o-rings instead of replacing the whole pipe as LR don't supply the o-rings seperately.
    The o-ring size is BS611. 2 in Viton (75) are required.
    The cooler gaskets can be replaced but if paying a mechanic then it's likely cheaper to fit a new cooler rather than spend the time removing the caked-on gaskets.
    Aug 2023
    Thanks Graeme, I was thinking it should be ok, but always great to hear other experienced opinions.
    One other thing, I have got the car back. Had a quick look and can get to a few of the bolts that are around the oil cooler coolant cavity from the top with a small socket with extension bar. Do you think there would be any benefit in nipping the bolts up an 1/8 of a turn to slow the leak ?
    NSW SW Slopes
    Possibly worth a try if you could get to them all, but if your coolant bottle isn't black with oil then there's not much of a leak. I changed mine's gaskets before any oil contamination but more often than not the coolant is well and truly contaminated before the work gets done.
    Aug 2023
    So I did tighten some of the bolts , but they are all tight - don't think it will make a difference. I also re checked the coolant bottle cold, and its black with oil maybe 2 or 3mm thick floating . Definitely contaminated.
    Going to suck out as much as I can from the top , run for a while with the cap open , and suck more out as it gathers on top.
    May 2003
    On The Road
    It might pay you to source those o rings yourself, then hand them to the mechanic.....
    Aug 2023
    Yes, planning to find the o - rings and get changed at the same time .
    Just an update to close this thread. I ran the car on and off for about an hour with the radiator cap off . Over a period of that hour , using a sump pump , I sucked out about 250ml of engine oil out of the coolant tank.
    I did my 10 hour trip and the RR did not miss a beat , whilst I did notice the engine oil level slightly drop. So back home again and car going in for a new oil cooler to be installed . Thanks everyone for your help and advice
    Nov 2013
    Wollongong
    They have been change twice on my car. O rings from bearing supplies about 66 cents each, not expensive. Common leak ,
    Jun 2024
    L494 SDV8 Oil cooler leak
    I have a L494 SDV8 with a leak that appears to be around the famous O rings. My question is what is the rough cost to resolve with new cooler etc ? Just trying to gauge the trustworthiness of the local specialist ?
    Nov 2013
    Wollongong
    I have had to revisit this as the replacement O rings sourced from BSC don't seem to be Vitron quality even though I requested them. So I have done some more research and decided on :
    Cat part number 464-0509 which is 1.78 mm section and 9.25 mm Dia .
    My son in law has a CAT maintenance business and had these in stock. They are Blue and are not rubber. He looked up the cat details, high temp and high pressure are the qualities.
    Cost $8.00 each.
    I intend to fit myself, seems this is a 1 hour task and might be a good project. I also recently replaced the oil cooler housing , O rings replaced same time but are now leaking.
