Thread: MS XLS divide IF function
    Feb 2010
    I am trying to divide a cell IF GST is applicable to the transaction. I know I could buy or use accounting software.
    My database bias is admitted.
    =IF(E7=”Y”,B20/11,0)
    Code is giving me a name
    E7 is simple Yes/No field and is 'Y'
    B20 in this case is 7451 number field
    I thought the B20 /11 would give me 677.30. It gives me a 'NAME' result.
    I have tried =sum(IF((E7=”Y”,B20/11,0)) and sumIF(E7=”Y”,B20/11,0)
    Checked column B is formatted as Number as is Colum C where the formula and result is wanted.
    PS- I sorted by Colum E and copied the simple formula to Divide by 11 as I am late as usual.
    NSW SW Slopes
    I can only get =IF to work correctly when the logical test is numeric rather than alpha but I haven't been able to trigger a name error.
    Jul 2020
    Urila
    Try retyping in the double quotes, they look wrong, maybe copy pasted from somewhere with different character set(?).
    Should be "Y" not ”Y”
    ex 2008 RangeRoverSport TDV8
    ex 1995 Discovery 1 300tdi
    Feb 2010
    Fixed it
    It is =IF(D47="yy",B47/11,0) worked for several thousand transactions
    NSW SW Slopes
    What is in D47?
