Results 1 to 10 of 12
Thread: SRS Dash Light Staying On....
    Aug 2012
    North Loburn, New Zealand
    Son's truck did some river crossings and after drying it for a while the SRS light is on. Used contact cleaner on the yellow pretensioner plugs under the seat, no joy.
    Fault code 0x90. Can see the SRS module under the cubby box. Looks a mission to get to....before looking to replace is there anything else I should first try?
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    Jul 2014
    west of Transylvania
    Quote Originally Posted by Tikka7mm08 View Post
    ....Fault code 0x90....
    That doesnt mean too much, read the code with a dedicated scanner which gives you a clear description of the fault and reveal that
    Aug 2012
    I'll try again... I cleared the codes to see if it was fine, before realising it self-tests and will stay off if AOK.
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    Aug 2012
    Ok - my son says the faults are on the left and right pre-tensioners, failure at ignition and failure to ground. Sounds like the module under the cubby box?
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    Jul 2014
    Clear the codes, unplug both pretensioners and read again... if the codes dont change in open circuits then the DCU becomes suspect
    Aug 2012
    Quote Originally Posted by sierrafery View Post
    So read while unplugged?
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    Jul 2014
    Yes, to check if the DCU reacts well or not
    Aug 2012
    Update. He cleaned the ground on one pretensioner and it has come right so he is trying the one with ignition fault code clearing, unplugging and reading.
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    Aug 2012
    Update, the unplugged ignition fault pretensioner returns open circuit fault... so if reading open circuit DCU is AOK and replace the pretensioner?
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
    Aug 2012
    Pretensioner is running 2.3 ohms so is ok. Squirting contact cleaner in and testing again plugged in.
    2001 Disco D2 V8
    2008 Defender 90
    2013 Disco SDV6
