Results 1 to 10 of 20
Thread: Nanocom advice
    Jan 2013
    Mt Barker SA
    Nanocom advice
    Hello folks hope everyone is good, I am seeking nanocom advice. Am about to embark on using it to bleed the abs system (had brake master cylinder fail, it was replaced and now brakes are still not at all good. Mechanics did the replacement and test drove but the brakes are going to floor. Wanting to fix myself but not sure the nanocom proceedure on bleeding them and abs.
    Thankyou in advance
    Back down the hill.
    Apr 2016
    Country Vic.
    Yeah, I did that too in the video, but what it doesn't tell you is to actually physically bleed the brakes. That is, to actually release the air out of the calipers too.
    First I did the one procedure as per the video, then did it all again whilst opening the bleed nipples on each caliper too.
    Doing it on your own tho, you need 'assistance' so I used the hose to bottle method.
    Each caliper separately, set up a small bottle with some fluid in it. Length of hose from bleed nipple to bottle and hose just inside the fluid in the bottle too.
    Search the net for howtos on using the bottle method for bleeding brakes, or you can purchase cheapish kits to do it.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Sep 2010
    The Hills.
    152.79 MB
    Arthur is correct. All of those vids show how to operate the nanocom, but not what to do on the car.
    This vid uses the Lynx diagnosis rather than the nanocom, but it might give you the idea.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jan 2013
    Mt Barker SA
    I was trying to find this diagnostic to buy after seeing this but can't find it anywhere Nanocom advice this seemed really easy to follow
    Quote Originally Posted by Tins View Post
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Epic_Dragon View Post
    The nanocom does the same thing, just in it's usual unique way. I showed you that so you would see the process for on the car, cos I can't find a tute for doing it with the nano.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    However, you can get Lynx from Britpart I believe. Lynx Diagnostics
    Personally I'd stick with the Nanocom.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Apr 2016
    Country Vic.
    I thought that the 'bleed' process was self fulfilling. Took me a while to work it out, but it's easy.
    I did the first two options to try to 'purge' the fluid first, thinking this may be required. Didn't matter if it was or not, didn't hurt.
    Then the next bit was(I had all four wheels off, but do it as you prefer) .. nanocom near the wheel as best as could be done(ie. either front pass seat, or drivers seat).
    Small tube from bleed nipple to bottle with a bit of fluid in it, to keep the end of the tube submerged in fluid, so no air could come back up the line.
    Then undo the nipple at the brake caliper that you're doing, go to nanocom and hit the bleed for that wheel.
    Really easy as pie(once you know what supposed to do).
    I think(can't really remember) I may have done each caliper twice, maybe three times to be sure to be sure, but with clear tube you can easily see no air coming.
    I seriously thought that doing the bleed did the bleed all on it's own, and you just used technology to do it, instead of 'gorilla power'.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jan 2013
    Mt Barker SA
    Thankyou so you did no manual brake pumping during this? Great for me as that is hard now using an arm haha. Going to try bleed it on Saturday Nanocom advice
    Quote Originally Posted by AK83 View Post
    Sep 2010
    The Hills.
    152.79 MB
    That's the point. Power bleeding does it for you. Imperative you keep the res topped up.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
