Results 1 to 10 of 12
Thread: Disco 4 front axle weight issues
    Oct 2023
    Gunnedah
    Smile Disco 4 front axle weight issues
    Hi
    I have a 2012 LandRover Discovery 4. It was 2nd hand to us and came with an ARB steel bull bar, WARN winch, side steps, and a second battery. We tow with it, so have become more weight conscious.
    I've recently had it weighed on its own and discovered the front axle weight is 1520kg when the max is 1450kg so we are overweight on the front with just me, my wife and a full tank of fuel onboard.
    I'm looking at how to reduce the front end weight - which is obviously removing the extra add ons or replacing these with lighter options. We really want to keep a bull bar on the front. The other add ons are up for discussion although we've used the winch a couple of times and the sidesteps are quite handy...
    We really love the disco so our first thought is to fix the issue rather than sell it - depending on the cost. Just starting to gather info for options. Have others had this issue and if so how have you resolved it? Any tips on what lighter bullbar and sidestep options are available?
    Thanks heaps in advance
    Al.
    May 2014
    Point Cook, VIC
    How much weight is on the rear axle?
    Others have more accessories than you listed and still end up below 1450kg on the front axle.
    Back down the hill.
    I wouldn't be worried about 70kg, the weighbridge could easily be that far out.
    Nov 2018
    Hobart, Tasmania
    I wouldn't be too concerned, the Road Transport inspectors seem more interested in checking GCM, GVM, c/van ATM and towball weight from what I read of people's experiences when they go through the checkpoints.
    That was certainly the case with one of my boys when he went through one in Qld a year ago and his tow tug is a late Nissan Navara with all the fruit attached, incl rear steel nudge side bars and rear bumper. Pretty sure it may not have passed the GVM but they were only interested that day in c/van ATM and ball downweight.
    Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
    Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
    North Avoca
    Quote Originally Posted by AlanM View Post
    Hi
    Al.
    I bought a 2013 D4 last year with the intention of kitting it out similarly to my previous two Defenders. That is, bull bar, winch, driving lights, long range tank spare wheel carrier, etc.
    Then I discovered the limited front axle capacity. So no winch and an ECB alloy bullbar. Maybe driving lights later.
    As to the rear axle, when towing I've got to be careful about filling the long range tank but otherwise I can keep under the maximum weight limit of the rear axle.
    So both axles in the clear.
    However, in your case, you need to keep in mind your car insurance.
    You might get through a roadside check by the police/RMS, if they don't check your axles individually, but in the case of a serious accident your insurance company might well be more thorough. Then you're down the gurgler when they refuse your claim.
    Mellow Yellow
    No matter what the problem - there's a solution. You've just got to find it.
    2013 Discovery 4 TDV6 3.0
    2015 Defender 90 - The TARDIS (Gone)
    2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
    2001 Discovery II TD5 (Gone)
    1986 County V8 (Gone)
    Oct 2023
    Gunnedah
    Quote Originally Posted by DiscoDB View Post
    1460kg on the rear axle - nothing in the back
    Oct 2023
    Gunnedah
    Quote Originally Posted by Mellow Yellow View Post
    Thanks - good points
    I've spoken to ARB about replacing the steel bullbar with an alloy one, plus removing the 2nd battery. Would get most of the weight back doing this. This insurance risk worries me leaving as is...
    Oct 2023
    Gunnedah
    Had a couple of weighs from different weigh bridges with similar results. I think the insurance risk worries me the most...
    Back down the hill.
    The insurance company would have to prove that the minor overload was a contributing factor to any accident.
    Back down the hill.
    Did you weight each axle individually, simultaneously or do a split weigh?
    Split weighs are notoriously inaccurate and can only be used as a guide.
