Results 1 to 10 of 17
Thread: Front Lower Control Arm Bushes
    Capel WA
    Hi,
    Can anyone help me with some info on which is the best way to go about refurbishing the front lower control arm bushes on my D4.
    Is it better to buy the bushes and tool need to remove and replace them or is it better to buy the control arms complete with tbe bushes already fitted?
    Regards:-
    Patrick M
    St Helena,Melbourne
    1.13 MB
    Depends if you are replacing them yourself at home or paying a workshop to do it, whole arms are easier to replace and will take less labour but the arms cost more.
    Bushes are cheap but labour intensive to replace and you'll need a good range of tools to do it.
    I've done just the bushes without removing the arms and it was still a difficult task.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    Adelaide
    It’s far easier to just buy new LCA’s complete with new bushes. It’s damn near impossible to put in the new bushes unless you have a 50t workshop press
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by John_D4 View Post
    Not really, i just used a manual bush replacement kit under the front of the car but the arms are designed in a way that makes it difficult to brace while removing or fitting the bushes.
    1974 VW Kombi bus
    Mandurah WA
    After deflating the airbag,this tool from Laser makes the replacement easy LASER TOOLS 6180 HYDRO SUSPENSION BUSH TOOL + INSTRUCTIONS FITS LAND ROVER 5018341061807 | eBay
    Beg ,borrow?
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by eddy View Post
    Beg ,borrow?
    Expensive tool to change just one of the many bushes in the vehicle, better off buying a press kit that will do all of the them.
    That clamp is really what you need to hold the arm.
    1974 VW Kombi bus
    Capel WA
    I was thinking of buying one tool to do all the bushes, but not sure if such an animal exists.
    From what I can piece together these bushes need replacing regularly, if that is so then replacing the control arm everytime a bush reaches it's use by date could be a constant drain on resources, whereas purchasing a tool that does all bushes could be a great saving in the long term.
    Time is not a problem to me as I am retired so hence my leaning towards an all round tool if there is such an animal.
    Regards:-
    Patrick M
    First time around buy replacement lower control arms and instal them. Take the old ones out and buy new bushes and just pay a firm to put them in for you on the old arms ready for next time - a cheap and easy way to do the job.
    Having said that my RRS has done 230,000km and is still on its original bushes - yes they do rattle a bit on driveways but are still holding up - on the weekend I drove quite a few kms on gravel corrugated roads with no issues.
    I have had a set of new HD lower control arms ready to go in for over 12 months and they are still in their box waiting.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Patrick M View Post
    Regards:-
    Patrick M
    I have a very nice 10t press tool.
    To do the front lower arms has a 6 piece kit
    Front Upper another 4 pieces
    rears are 2 more kits for the arms
    Hub bushes on the rear is another 2 sets
    Because of the way the bushes protrude its not as simple to just mandrel press them
    St Helena,Melbourne
    1.13 MB
    A bearing puller plate and a bush press kit is what i used to do mine, not perfect but the kit will do all the other bushes as well.
    I'll dig out the photo's when i find them.
    1974 VW Kombi bus
