Results 1 to 2 of 2
Thread: Electric power steering racks PSCM in JLR vehicles - virginise used ones
    Jul 2015
    Sydney, Australia
    Hello everyone,
    I'm pleased to announce another breakthrough with our own in-house programming tool JLR-UDS.
    We can now virginise the electric power steering racks (PSCM) in JLR vehicles, that you can fit a used rack assembly complete and it can be programmed to the vehicle just like a brand new one, with correct VIN, calibrations & steering tune.
    Until now fitting a used PSCM was 99% sure to be a drama show, but not anymore. With brand new racks retailing for $7500 these days, finally there is an economical and simple alternative. The racks are often damaged in a front-end impact, but we saw a couple that spontaneously just failed, with the motor/module assembly no longer operating or communicating.
    We can do PSCM for Land Rovers up to the end of the "existing" models, so L494, L405, L462, L538, L550, L551, L560. At this time we realise that the racks in the new models L460, L461 & L663 are different, but as soon as the opportunity comes up we will get onto it.
    Jaguar models from XE, XF, E-Pace, F-Pace, F-Type, later XJ's are no problem either.
    Source yourself a complete rack assembly from your favourite wrecker, and we can virginise & program it with it installed in the vehicle via OBD, no need to break factory seals, swap motor assemblies or otherwise compromise the replacement unit.
    Or it can be virginised on the bench to be programmed later on with SDD, Pathfinder, etc, once installed in the vehicle.
    It is also possible to use rack assemblies from the same model but different model year; e.g. a rack from 2016MY L494 fitted into 2014MY L494.
    This is a proven solution, we have programmed a 2nd hand rack to a 2017MY L494, works perfectly with no fault codes or surprises.
    I'm personally offering this programming service for those in Sydney, and this capability will be available to our interstate partners too.
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
    Mar 2024
    Lincoln, England
    Help from the other side of the world
    Morning
    Ive jus joined hoping you can help fix my issue
    The motor died on my old rack on my 2013 L405, ive sourced another motor but its a used unit and needs virginising
    How much do you charge please and are you able to help
    im based in Lincoln in the UK
