Thread: Disco 4 2.7 v6 overheated
    Oct 2023
    Australia
    Hi mi disco 4 overheated at highway speed no sign of temp rise engine when in to limp mode the shut down when pulled over, found the coolant block in valley had split in half dumped all coolant in a hurry. Have now changed housing refilled. Engine cranks with no noise but won't fire bubbles pressurises header tank I'm thinking head gasket range rover dealer reckons engine is done needs replacement engine quoted 13k for used engine fitted thought it was a bit rough for and over heating prob,any ideas?
    Hunter Valley
    Sorry to say, but the dealer is correct. You could get the head gaskets done on your engine, but the labour costs would bring you to about the same money. The engine needs to be removed either way you go. Not having the temp gauge rise is normal. It's not a Land Rover thing. When they are not in coolant, they don't read correctly. You could shop around, and you might find a cheaper price to install a new engine. I have an engine guard temperature monitor on every car I own to monitor overheating.
    It doesn't leak oil, Its sweating power
    St Helena,Melbourne
    4.28 MB
    Head gaskets can be done with engine in situ, another cheaper option is to get a territory motor which can be bought for 2-5k plus fitting.
    Get a quote from an indy not an LR dealer.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2014
    Perth Western Australia
    There is no cheap option for a Discovery 3 / 4 with a failed / overheated engine.
    *$13K price is likely a Territory engine, its cheaper than I do them for. People often fail to account for labour and the amount of work involved.
    *Also not many low mileage engines around now.
    *lucky it's not a 3.0 otherwise you might as well sell it to a wrecker.
    Other things to think about...
    *Has the top coolant outlet ever been changed?
    *Has the timing belt recently been replaced?
    *If so why didnt they change out the top coolant outlet at the same time?
    Daz
    Brisbane,some of the time.
    Even at $13K,is it really worth repairing?
    Probably not,and no doubt at that age,the vehicle will need other repairs at the same time.
