Thread: Hello! And hopefully not goodbye...
    Oct 2023
    Cool Hello! And hopefully not goodbye...
    Howdy folks, long time lurker first time poster
    Bought my '01 P38 about 2 years ago, has 430,xxxkms on the clock, with an engine rebuild done about 70,xxxkms ago by the folks over at Graeme Cooper.
    It's not been without its issues, I've pretty much replaced the entire cooling system apart from the water pump. Very recently replaced the radiator AGAIN after the other one I bought about a year ago started leaking (Hopefully because it was cheap and not because of a headgasket-overpressurizing-issue).
    The aircon is munted, I only get $SOMETIME of cold air before the ac gas leaks out somewhere. Everything leaks oil, and as I mentioned, the cooling system has needed some love.
    I've become a father since owning the P38 and so I don't get as much time to work on it as I used to. My wife is nudging me to sell it for something more reliable (So I don't have to steal her car to tow my boat when the P38 is out of action), but I'm a bit attached.
    Took it to Davis Performance Landy's the other day, great bunch of folk, to get the ac regassed so we can try track that down, and also got them to do a full vehicle report and it's quite the list of problems...
    - Maybe slight rear main seal leak
    - Engine sump oil leak
    - Steering damper oil leak
    - Front top and bottom ball joints could do with replacing on both sides
    - Slight transfer oil leak
    - P0135 on the oxy sensor
    - Left blend motor issue
    - Left and right blower motor issue
    - In car temp sensor cooked
    - AC condensor fans not working (I'm pretty sure no ac fan works properly on a P38, but the viscous fan is powerful enough for this to not be an issue, I think)
    Anyway, I'm not really sure what the point of this post is other than to say hi and hoping you'll talk me out of buying a different car
    Back down the hill.
    Yeah, but what about the bad points?
    A Land Rover is part of the family, not merely family transport. You'll grieve for it, if you abandon it.
    St Helena,Melbourne
    4.28 MB
    Rear main seal is probably the biggest job in the list and the others are not too bad, certainly not bad enough to get rid of it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2010
    The Hills.
    152.79 MB
    I think I'd rather tackle that than the ball joints...
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Oct 2023
    I'm liking these replies
    I've heard the ball joints can be a big pain. At least they are DIY-able, though.
    I'd like to try fix the other things, the dash is already somewhat pulled apart for some cosmetic repairs, so I could do the blend motors and possibly the evaporator if that is what's leaking the AC gas.
    As for the rear main, that might be a bit above my skills, I'd enjoy giving it a whirl, but don't have access to a hoist or engine crane etc.
    Jan 2016
    Netherlands
    Mate, that's all?
    The rear main seal is "just" a lot of work to get to but a quite easy fix otherwise. When you are in there check the flexplate and perhaps replace it.
    In any case, yeah hopefully not goodbye but our girl is definitely playing up a bit too much lately and is certainly moving closer towards the exit. Can't say mine has been unreliable, just reliably broken
    Ah and yes, those ball joints would worry me. Recently done -one- on a Jeep TJ (same principle, much smaller axle) and with normal tools it is almost impossible to do.
    -P
    Oct 2007
    Williamstown, Victoria
    Hi enjoi, I also have a 2001 and have dealt with most of the items on your list.
    We all get attached to our P38's, you are not alone in that department!
    I can understand the time factor with a new baby in the family, but if you are able to tackle one job at a time, you will be able to work through your list over serveral sessions.
    I tend to do most of the work on mine during the warmer months, (I'm in Melbourne), it's no fun working under cars in the middle of winter.
    I find with many of these things, the hard part is actually starting the job, once you are into it. it's not as bad as you were imagining, (most of the time anyway)!
    AC is one of those jobs that needs expert attention, I had a leak on mine a few years ago and the AC tech found a leak on one of the hoses.
    I got the correct hose and fitted that myself, the AC guy came back and re filled the system, it's been great ever since.
    I think I have this as well, have not attempted this repair as yet.
    I would give the engine a good clean up with degreaser and have a good look after a couple of days, oil will move downward with gravity, so you can often trace the source of the leak by following it upwards.
    Fans can spread oil all over the place, which makes it harder to trace, so if you do a clean up and check, you should be able to pinpoint the leak with a good torch.
    I did my sump (oil pan) gasket last year, it's not too bad to do, just lots of bolts and a good clean up of the sealing surfaces, along with a new gasket.
    This can be a bit of a dirty job.
    Make sure you torque the bolts up to the correct specs and apply black RTV in the correct spots as per the rave manual.
    Probably just a new damper required, 3 bolts, easy job.
    This is a bigger job time wise, there are kits with the correct tools required to press out the old ball joints.
    It is doable as long as you have enough time.
    With jobs like this, I always find the first side takes a while, the second side is much quicker, as you have all the tools required on hand and the know how from the first side.
    I would give it a clean up and check again after a day or two to try and identify where the leak is coming from.
    I did my 02 sensors last year, easy job, take it from me, only use genuine Bosch sensors, Thor engines don't like aftermarket 02 sensors.
    You will need diagnostic equipment to plug in and reset the adaptive values once the new sensors are installed.
    This job is more fiddly, but very doable. You have to remove the glove box to get to it, then bend the black pipe out of the way, a long phillips head magnetic screw driver is a big help with this.
    I cut the wires on the old blendmotor and fitted spade style elecrical connectors, did the same the the new blend motor, that way I can just plug a new blend motor without pulling everything apart next time. And there will be a next time!
    I had a right blower motor fault, there are videos on you tube showing how to take the blower out and clean the relay. I did this and it did not solve the issue, so I got a good second hand blower sent from Triumph rover spares in SA. That has been working really well since with no issues.
    As you have to remove the glove box to do the left side motor, you may want to do the left blend motor at the same time.
    This is pretty easy, it unclips from the heater pipe and and the new one just plugs in.
    This could be a relay issue, I'd check fuses and relays first.
    They only seem to kick in when it's a really hot day, so yours may actually be working.
    You could probably apply 12v to the fans to check they spin up.
    I hope that is of some help, let us know how you go!
    Cheers, Pete.
