Thread: 300TDI fuel lift pump
    Aug 2008
    16.28 MB
    Where can Iget a liftpump for a 300TDI
    My localparts places are saying that they are not avail
    Aug 2008
    16.28 MB
    pump
    Yes,thats itThoseblokes don`t know their job
    Thankyou,I reckon Karcraft would have one as well,but they are not open today
    Thankyou very much
    Thankyou
    Quote Originally Posted by INDABA View Post
    Generally speaking, KLR aren't open Saturdays either but there is often someone working. However, I think the phones switch to messagebank after hours so no-one will know you are calling. You'd need to just go there in the hope someone is working.
    Sep 2010
    The Hills.
    152.79 MB
    That's a pretty good price, Ron.
    Very important with the 300TDi pump that the correct thickness spacer is used. That doesn't always mean putting back what is there, as some PO may have screwed it up.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    double gasket both the lift and vac pump.
    but then...
    turf the mechanical lift pump and fit a facet pump.
    They aren’t cheap.
    Facet Fuel Pump, 12V - PRC3901
    Sub 20 for the cheap ones on ebay (with postage) Universal Electric Fuel Pump 12 volt Solid State 4-6psi 130 LPH Petrol Facet AU | eBay
    sub 40 for the not so cheap ones (with postage) 12V CAR ELECTRIC UNIVERSAL PETROL FUEL PUMP FACET POSI FLOW STYLE KITS AU | eBay
    aournd 70 for the ones that have servicable centers and filters (with postage) 12V Electric Fule Pump Diesel Petrol Facet Red Top Style Car Truck Caravan 8mm | eBay
    any one of those 3 will get the job done for a tdi300. and all of them can be paralleled with the fuel solenoid without popping fuses AND, if you get clever with the hookup you can also tie some of them to a relay and the oil pressure switch so it will cut out if the engine stops.
    sub 40 for the not so cheap ones (with postage) https://www.ebay.com.au/itm/35355192...3ABFBMqMfXn_hi
    Queensland
    "turf the mechanical lift pump and fit a facet pump."
    Wot he said.
    All my 200 TDI,s have one now.
    If you think Landies are hard to work on , dont try a Skidsteer. My Toyota SDK6 has a Facet now too as I could not get anywhere near the original.
    Keith
