Results 1 to 9 of 9
Thread: Offset Logo on Terrain Settings
    Nov 2023
    Adelaide
    Greetings all,
    All going well, I will be picking up a 2016 Discovery 4 this weekend. I have owned a Discovery in the past (albeit a Discovery Sport) and I am fully aware of the love/hate relationship with these cars. But I thought I'd start my first post with some real important stuff. Why... Why are the logos offset for the terrain settings? Is this a part from a different generation or model that they've reused? No sane person could allow this without good reason?!
    Is there an aftermarket replacement? If not, I'm going to see what I can come up with for the sake of my own sanity !
    Back down the hill.
    I'll take a guess and say, perspective in a LHD car.
    Brisbane,some of the time.
    Or being an LR,it probably matches lots of things that are slightly offset
    May 2014
    Point Cook, VIC
    Looks like you are missing one of these:
    …but maybe yours is just in all black with a black background so you Don’t Panic!
    Back down the hill.
    Check that the above light works, when first turning the ignition on. It maybe disconnected to mask an expensive problem.
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Squeak View Post
    Greetings all,
    A check of adverts in the UK reveals the same phenomena.
    In the USA there are only 4 icons which, (cue Gomer Pile - surprise, surprise, surprise) are centred in that space and so not offset. The fifth that is added to the RHD versions is the extreme right - rock crawling.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Nov 2015
    Black Rock
    No. As I've explained before, that spot is for the child eject option.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Jul 2015
    Sydney, Australia
    Actually it’s because the same basic panel is used in the Range Rover Sport, and that empty spot is where Dynamic Mode would be in a suitably spec’d RRS.
    You can’t retrofit or activate Dynamic Mode in a D4, before anyone asks. So just get used to how it looks.
    The USA spec LR4’s missing the Rock Crawl mode on the far right have single speed transfer case. No low range so no Rock Crawl. Actually I saw one local D4 the same here a while back.
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
    Oct 2016
    Perth, AU
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
