Results 1 to 3 of 3
Thread: Salisbury diff bearing numbers
    Narre Warren South
    I'm trying to help someone out who possibly needs bearings replaced in the front diff of a 101.
    I need the Timken inner & outer numbers for each bearing (not the Land Rover part numbers).
    I've found a few threads and got a couple of bearing numbers
    Pinion bearing HM88649/ HM88610
    Carrier bearings 382S cup/387A cone
    There seem to be kits available from the UK but they either have a mix of Timken & Koyo or don't even mention the bearing manufacturer.
    If someone could confirm the above numbers and supply the missing pinion bearing number I can get a price from a local bearing supplier.
    Thanks,
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    KLR's website shows a Koyo bearing. I can't quite make out the bearing no. In one of the images, it looks like 3828-N
    Rear Salisbury Diff Carrier Bearing, Defender/110/Perentie - 607187
    Narre Warren South
    It's the carrier bearing so probably the same as Timken 382S
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
