Results 1 to 10 of 17
Thread: URGENT HELP NEEDED !
    Apr 2015
    melbourne
    Hi all,
    2009 disc 3 , v6 petrol
    I am trying to take off this stupid fan so I can get to the belt and replace it.
    I am seeing on youtube that to take off the clutch fan belt, when standing Infront of the car, turn the 36 mm tool to the right.
    Is this correct?
    I am using the pray bar and land rover 36 mm tool and it is not budging, I cannot believe it is that tight.
    The one my discovery 2 comes off like a butter.
    I have feeling I might also have to by this to attach 2 bolts on the water pump pulley ?
    Fan Holding Tool total tools - Google Shopping
    Need advise asap.
    Thank you.
    Apr 2012
    Whyalla, SA
    Try a couple of sharp strikes on the spanner with a hammer…
    Shock often gets it loose.
    Hunter Valley
    The fan on a v6 petrol is a right-hand thread. Diesel and v8 left-hand thread.
    You will need to go lefty loosey
    It doesn't leak oil, Its sweating power
    Jun 2008
    Drouin East, Vic
    They can get tight- especially if some goose has put loctite on them! To ensure you're turning the right way (and I don't know which way is right for your engine) make sure you're turning the fan (nut) in the same direction it turns when running- you can tell by looking at the way the blades are oriented. It varies with different engines and belt arrangements. To hold the pulley, any homebrew arrangement of flat bar with holes that fit over the heads of two of the bolts. See here for some examples examples TDV6 fan pulley holder tool it doesn't have to be pretty, just has to somehow capture 2 bolt heads and have a handle. Mine is exceedingly ugly and took less time to make than to post this reply.
    Apr 2015
    melbourne
    Thank you all..
    I've been swearing every English engineer that ever lived... did my head in.
    So you are saying I should be turning the 36 mm spanner tool to the left of me when standing Infront of the car?
    See, v6 different to v8 and diesel engine...
    Thanks Pod I will look at that too..
    Apr 2015
    melbourne
    I will post you the pic of the fan .. I somehow have a feeling the 36 mm should be turned to the left..
    Sep 2014
    Baldivis WA
    Yes if a rh thread, then turn to the left to undo
    St Helena,Melbourne
    1.13 MB
    i made a bracket that uses 2 of the pulley bolts and then rests against the engine to hold it while undoing the fan- TDV6 that is but same principle will work.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2015
    melbourne
    Hi all,
    Please see pic below. Taken from the front of the car
    I am not attempting to do this unless I am 100% sure which way to turn the 36 mm.
    What a bastard , something so simple..
    NSW SW Slopes
    The blades pull air by turning anti-clockwise, so unscrew in the same direction, ie turn the spanner to the left from the top.
    Notwithstanding that you've been trying in the wrong direction, it will probably still loosen with only a gentle tap.
