Results 1 to 9 of 9
Thread: Roof Rack Solar - Below Load Solar Panel Mounts
    Sep 2022
    Cool Roof Rack Solar - Below Load Solar Panel Mounts
    I discovered these products recently manufactured in OZ by TLR: Solar Panel Brackets - Rhino-Rack Vortex/Heavy-Duty Rack - TLR Products
    They let you mount a solar panel under the space where you would load your roof racks.
    This is great for me:
    - get clear view of the sky if you park in the sun
    - mount once
    - can still carry stuff without removing panels
    - don’t have to get them out/pack them away/plug them in
    - can’t aim them - I have to leave them alone
    - shades the car
    - are black
    These are made for a few types of racks, but I had Yakima Aerobar which meant
    - have to mount the front bar backwards
    - have to mount the panel 20mm away from the end to clear legs
    - can’t have mount/edge of solar panel at legs
    Even so I managed to fit 200W (100W Renogy Black x 2) with some black Ali angle to join it into one panel
    I run the power down the side of the tailgate but it could be done like the roof top aerials.
    They even stay on when you roll the car!
    Mar 2016
    Adelaide
    I think that redarc make a similar product by memory
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Sep 2014
    Hunter Valley NSW Australia
    If you want to be able to collect solar when stopped but have stuff on the roofracks then mount them on drawer sliders so they can be either slid out over the windscreen or over the tailgate, bonus is they then give some shade to both those areas.
    Sep 2022
    Drawer slides is an awesome idea!
    TLR manufacture the ones for Redarc, they are the same couple of products.
    Quote Originally Posted by oka374 View Post
    I’ve been wanting to do this for a while. One day.
    St Helena,Melbourne
    1.13 MB
    My only concern would be the slides rusting so that rules out the ball bearing type, ideally something like nylon or HDPE in aluminium C channel .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2010
    The Hills.
    152.79 MB
    What a good idea. What we need now is for someone to come up with a solar panel awning.....
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2014
    There's plenty of those already in use, on Oka's too over the rear window if they have one. Side mounted solar panels are a problem on anything used in the bush though.
    I've seen a coaster bus with them mounted on both sides and the rear, forget how much they generated but it was more than enough to power a split aircon.
    Electric actuators are now cheap enough to use for the purpose. There are light duty drawer slides with nylon bearings which would do the job.
