Results 1 to 10 of 13
Thread: Rooftop tents for L320
    havent been successful in a forum search on this but I am sure I wouldnt be the first to ask.
    Has anyone put a rooftop tent on their l320 and what style of rack was used .
    Apr 2012
    Whyalla, SA
    Use factory roof rails and 3-4 cross bars
    Will the factory rails hold the weight ( circa 170kg plus tent ( 70kg) ).
    I thought I would have to get the metal flat tray for it to go on?
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by PeterAllen View Post
    You don't want a tray rack as they are heavier and you are already overloading the roof.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2020
    Urila
    I used the Rhino racks tracks and just two cross bars to mount a James Baroud roof top tent with no problems on the highway or being thrown about in vic high country. The James Baroud is only about 50kg, a bit more aerodynamic that the fold out canvas type roof tops and because it only pops straight up there could be less strain on the racks when in use ( ie depends on the design of the RTT you use).
    Not sure if racks verses bars makes a big difference more than the number of legs and method attached to the roof. The L320 roof has provision for fastening tracks to the roof with with 5 M6 bolts each side. Factory roof load is 75kg.
    ex 2008 RangeRoverSport TDV8
    ex 1995 Discovery 1 300tdi
    Thanks all.
    I will investigate the Rhino rack rails and a few crossbar then.
    Note peterjj that you stick a wheel up there as well as the roof top tent. I might look at 3 or 4 cross bars as suggested to ensure I am not overloading it.
    From the photo do you have a winch installed on the front? If so could you post a photo of how that was installed.
    I have the Rhino longitudinal roof tracks fitted and they were easy to fit. I have two of the Rhino roof bars fitted to that - again easy to fit. I do not have a roof top tent but have a normal basket type roof rack bolted to the roof bars. I would use a third cross bar for a roof top tent.
    The only issue is the shape of the RRS roof - is higher at the front so what is on the roof sticks up a little unless the height of the rear feet can be adjusted higher - mine cannot.
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by 101RRS View Post
    Could do a simple spacer between rail and cage and would work Rooftop tents  for L320
    Brisbane,some of the time.
    Quote Originally Posted by peterjj View Post
    Had the same on the D4,and now the LC200,with a JB tent,and Rhino Batwing awning.
    Used two HD bars,with tracks,like others have said,a third bar is a pain as it has to be packed to line up with the others.Although Rhino do have the packers,and longer bolts to suit the HD bars.
    And for a JB RTT, not needed.
    The set up on the D4 was on the limit for it's specified roof load,but no worries on the LC as it is rated double the D4's roof load.
    Travelled all over the countryside,lots of corrugated roads,etc,etc,no issues.
    Our JB weighs around 65Kg.
    Note also they specify a distance from the front of tent forward of the front bar,i think it is around 450mm,which is no problem as the bars can be moved along the rails.
    Thanks all,
    Will review the path of the Rhino rails.
    Called into ABS and 4wd warehouse and niether had any rack suitable for the Sports. In addition, the light loading of the roof is a concern for putting a bit of weight up there.
    Nice looking vehicle 101RRS.
