Check it has had the belts and oil pump replaced as it should be on its 3rd set by now. It looks like a reasonable buy at the higher end of the market but has about 3k or so in the bar and snorkel.
Shouldn't have any leaks but then seal age and fail, got some peace of mind from a dealer at least, trans should be really tight still but will require a fluid/filter change.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
