Results 1 to 10 of 11
Thread: 12v Actuator For Pop Top Camper
    Mar 2016
    Adelaide
    I’ve got a pop top camper with 4 x scissor lifts. It works fine and it really stable but I’d like to make the lift easier. I’m aware that I can install struts but that still requires some manual lift. Installing internal lift bars at either end is not possible with this style of camper.
    The new model comes with vertically mounted 12v actuators, but the new model has smaller side draws to make room for the actuators. I’m not prepared to lose side draw size to fit actuators vertically.
    Would there be an issue with 2 or 4 externally mounted 12v actuators, mounted on an angle like struts are mounted? I understand that they might need a synch control box and definitely compressor. This sort of thing:
    Bullet Series 36 Cal. Linear Actuators
    I’m really handy and can do all the work myself. I’m aware of front and rear lift bags - that’s also an option, I just thought that I’d explore this option 1st.
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Sep 2014
    Hunter Valley NSW Australia
    When I built/fitted out the camper in the Oka bus body the poptop had a central handle on each side that were used to lift the roof. The roof also had a scissor lift on all four sides.
    It worked well with two large solar panels and a Fantastic vent but when I started fitting more panels it got to the stage where it took two people to lift it which isn't alway possible so I fitted electric actuators to the lifting handles which are horizontal when the roof is down and vertical when the roof is up.
    It took me a while to work out mounting points and travel distances but two 120kg 200mm actuators from ebay along with the supplied actuator control box complete with fob have down the job now for about 10 years.
    They are similar to https://www.ebay.com.au/itm/27626297...Bk9SR6ae5tmcYw
    They pivot well on the supplied bracket and pins and there are lots on ebay and most sellers will have the actuator controller etc. Just need a twin core cable run to each actuator from the control box.
    Mar 2016
    Adelaide
    Good idea. Unfortunately the lift handles won’t work on my camper. On the below pic you can see the distance from the top of the bed to where the top comes down on to the metal. There’s not enough room for a person to climb into the bed to activate a lift handle. There’s storage under the bed which is why the bed is high.
    Correct me if I’m wrong, but you suggested installing lift handles with actuators? Sorry if I’ve misunderstood.
    Back of camper:
    Front of camper (top bunk folds flat to make a lounge):
    Apr 2012
    Whyalla, SA
    I believe he said he had handles, until the roof got too heavy due to solar add ons etc.
    He then fitted actuators to resolve the problem.
    Mar 2016
    Adelaide
    Would you have a pic Oka? I’m not quite grasping what you mean
    Sep 2014
    I had overcentre handles midway down each side which I fitted actuators to when the roof got too heavy to lift.
    You don't have the handles but you could fit actuators vertically middway down each long side and they would easily lift the poptop.
    I suspect that like most poptops yours is initially hard to lift but once it gets up enough for the scissor lifts to operate then it is much easier.
    In your case you only need to lift and pull down when closing so the actuators are not lifting the whole weight of the roof or even locating the roof, only lifting or pulling down mike mine.
    So they only need to be anchored firmly at the top and bottom, you just need to find a secure mounting point on the wall and the ceiling.
    The travel required is the distance the poptop rises so that is the operating length of your actuators. The ebay ones come with an actuator "box" and a fob remote that can be operated in two modes, either in one touch where the actuator operates until its inbuilt limit switches are operated or it operates as long as you hold the button in whichever direction it's travelling.PXL_20230513_063838891.jpg
    Sep 2010
    The Hills.
    152.79 MB
    I was looking at these for my OKA
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Queensland
    Quote Originally Posted by Tins View Post
    What happens as they deflate going down> I would be worried they might fall outwards and get stuck between the outside edges and get chaffed etc.
    I have 4 scissor lifters and use a D handle centre each side to lift and pull down. I had to remove a spring from two of the scissor lifters before I could get it up or down easy. Even now I have to get my back under the roof to start lifting when its down.
    Keith
    Mar 2016
    Adelaide
    I have thought of the lift bags also. I’d thought about mounting them here:
    But I’d prefer to use actuators if possible. I’m still open to the idea.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by 123rover50 View Post
    Keith
    I haven't got them yet. I too want to see them in action. In the OKA I have to push up with my head, something that isn't ideal since I broke my back.
    I just looked at this again. Seems they will just fold up with the canvas.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
