Thread: Blackvue coax cable connector
    Dec 2016
    I finally installed my Blackvue DR750X 2CH dashcam. The front unit was easy but I wanted to mount the rear camera on the tailgate glass which meant routing the cable from inside the cabin to the top tailgate. I tried to squeeze the connector through one of the OEM rubber boots but it was too big, so I bit the bullet and cut it off...
    How hard could replacing a coax plug be? Quite challenging to find the right connector to start with
    This is the connector I bought:
    MCX Male Crimp Connector - RG174/RG178/RG188/RG316
    And these so I could see the internals of the 2.5mm cable for soldering and crimping:
    https://www.ebay.com.au/itm/155919096065
    In the end, it worked first go - but was very fiddly.
    Hope this helps someone else.
    Nuggets
    Discovery 4 3.0L 2010
    Mar 2016
    Braver than I. I persisted.
    2007 Audi RS4 (B7)
    Dec 2016
    Ha nice one. I was scared that I'd get it stuck half way.
    Looking at it now I think you could use the right side boot, remove the washer hose, thread the cable and reinstall the hose. Maybe?
    Oh well, done now.
    Nuggets
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Disco4TT3 View Post
    Pushing 50, I now can't live without these. I keep one in the D3, one in the Van and one at home.
    Good job getting an MCX first try. Fiddly little buggers.
    Mar 2016
    Adelaide
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Jan 2010
    Quote Originally Posted by BradC View Post
    In case you can't find the magnifier/s, you can film tiny writing on your phone and the zoom in to see it, more difficult to do if you are working on a fiddly part though.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Mar 2016
    Quote Originally Posted by RANDLOVER View Post
    Or on an Apple device, you can use the inbuilt Magnifier app, but that doesn’t help you do what was done here. I need one of those thingies. I’m going blind.
    2007 Audi RS4 (B7)
    Dec 2016
    huh - I did not know about the magnifier app. Could be handy in a pinch!
    Nuggets
    Supporter
    Mar 2018
    Perth (near Malaga)
    Only in a pinch. A mate taught me to use the camera to blow up menus I couldn’t read because I reversed over my glasses. To use it in anger though would mean putting down the soldering iron or crimpers. Oh to have been born with 3 hands.
    Apr 2012
    Whyalla, SA
    Fits through easily.
    I’ve got the camera coax and a couple of lighting power feeds added through the factory ‘tubes’
