12th January 2024, 12:59 PM
desiccants for air compressor
Unfortunately i droppped my prills on the floor
I found this site ordered 500mg which was the smallest pack offered
anyone need some i can share
I am always amazed when i pull stuff off of my d4, to see no grease, lanacote or anything else on threads
I steer well away from **** like loctight, in fact i grease the caliper double hex fastening screws and lean on the powerbar, in 60 years doing all manner of mechanical and engineering and marine stuff, lubing threads is the way, the cyl head caps screws on a 855 cube Cummins are 15/16 inch , we always lighty oiled the threads and the washers under the screw head, only was to get a true reading on the torque wrench
only reason i thought the desiccant was stuffed was the message on the code reader that the air was not dumping, well at least i can replace it with hex heads on those rubber shock pads , the 4mm allen round heads are bloody stupid
so there
Silica Gel Beads - Indicating Blue to Pink
