Results 1 to 4 of 4
Thread: 3D scanner review.
    Sep 2010
    The Hills.
    152.79 MB
    3D scanner review.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Apr 2012
    Whyalla, SA
    If you have a later iPhone you have a LiDAR built in that does an amazingly good job.
    Mar 2010
    Queensland
    12.97 MB
    Hello Tins,
    Thank you for posting the review of the scanner. I was surprised by the comment that flat thin objects with holes in them caused the scanner to have issues with scan quality. My thoughts of getting a scanner were to be able to scan mechanical parts - most of these would be flat and relatively thin. Plus, they would have holes in them.
    The idea being that the scanned image of say, a broken clamp on a wood lathe could be glued together and then scanned. The scanned image could then be 3D printed and the printed object could be used in either a lost wax mould, or pattern maker's sand mould. From which the cast metal or alloy replacement part could then be made and the machine subsequently repaired.
    Of course there is a less technologically advanced solution that takes into account my lack of a digital milling machine. I could get a billet of steel and grind off excess material with an angle grinder. Plus drilling out holes of the slot in the clamp. I could finish the job with lots of hand filing. It is not a precision part so I do have some leeway for possible small inaccuracies.
    I thought scanning - printing - casting would simply be lots more fun! Yes, this technique does not remove the need for finish filing.
    For example, Lost Wax Casting and 3D Printing accessed 29th of January 2024 from, Basics of Lost Wax Casting with 3D Printing - KAYA-CAST - YouTube
    Sand Casting and 3D printing accessed 29th of January 2024 from, Making a cast iron flywheel from a 3d print - YouTube - this clip is from Windy Hill Foundry and the bloke is an amazing artisan. My apologies that the 3D video is not Windy Hill's best video. There is normally less fast forwarding and better descriptions step-by-step of what he is actually doing at the time. It was the first video I found from his YouTube page that featured 3D printing.
    Kind regards
    Lionel
    Sep 2013
    Darwin
    12.74 MB
    Quote Originally Posted by Lionelgee View Post
    ...a broken clamp on a wood lathe...
    Provided you have a decent heat source then you may be able to silver solder it or alternatively braze it, depending on what the bracket is made of. Weld it? Try and keep the original roughness of the break for keying/locating rather than smooth off.
    Have you had experience with iPhone Lidar scanning holes in thin flat plate, issue described by Lionel? Let us know when the iPhone can do cosmic ray scans
    I've used a laser pointer to create concentric circles around the z axis to locate holes on the the xy of the original object, transferring the co-ordinates to a duplicate piece or incorporating into a CAD drawing of the original - using a milling machine with analog vernier scale - and tedious.
