Results 1 to 8 of 8
Thread: Battery and Alternator
    Mar 2007
    Tarneit VIC
    Hi
    I have experienced twice in the morning where the car (D4 SDV6) took a while to crank and start. I also got yellow/red triangle after that but after I switch off and start again, it starts easier and no warning light. I suspected the battery. I charged the battery over night a couple of weeks ago and it slow crank and start happened again this morning. The car is a daily used but only short distance in 1 trip, around 10-15km in average.
    I also just purchased secondhand Gap Tool. Is it possible to see if the battery or the alternator need to be replaced from the Gap Tool?
    Gus
    Nov 2015
    Black Rock
    You need a battery tester to check the battery. However, your short drive each day is not helping, so expect the battery to only last two to three years. Also, once the car has travelled around 150,000km it's time to consider replacing the alternator. They tend to go at around 170,000km. Your use of the car translates as arduous conditions, so you can expect other stuff like discs and pads and fluids to need regular replacing. To this end, I hope you are replacing the engine oil and filter every 10,000km, gearbox at 90,000 and every 40,000 thereafter, diffs and transfer case every 40,000 and brake fluid every two or so years.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Sep 2014
    Baldivis WA
    Short trips kills these cars and most diesels imho.
    Need to go for a long drive and "give it the berries" as they say.
    The smart alternator in these cars only put out the current that is being asked for, so short trips does not allow them to top up the battery sufficiently, more than likely the cars electronics are being run off the battery, and the alternator just (barely) maintains a float charge on the baytery.
    Mar 2007
    Tarneit VIC
    What’s the battery specifications for D4 sdv6?
    Mar 2007
    Tarneit VIC
    Check main battery voltage on IID tool.
    Car running: 13.8v to 14V
    Not running: 12.5v
    Starting: drop to 9.8V in the process
    From those data, can you tell whether the battery or alternator needs replacing? Thanks
    Mar 2016
    Alternator is fine. Get a new battery
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    Quote Originally Posted by fourteen8 View Post
    Not running: 12.5v
    When voltage drop below 10v at start up, battery is done for
    Mar 2007
    Tarneit VIC
    Thanks everyone
    Bought Varta G14 for $580 delivered. Hopefully it will be here tomorrow
