Results 1 to 10 of 13
Thread: TD5 Over full sump.
    Wodonga
    TD5 Over full sump.
    Hello,
    Before anyone starts to say anything, yes I DID search the files to find an answer to my question, but I didn’t find anything.
    Problem, Over full sump.
    My Guess: diesel diluting oil. Definitely no water.
    Cause Cracked head, seals on injectors?
    ALL oil changed every 10,000Kms. Motor is totally stock apart from EGR removed.
    Never over filled, ever. What could be the cause? The current oil has done about 8000Kms.
    Hopefully there is a foto of the dipstick, finger crossed.
    Thanks for the replies
    Sep 2010
    The Hills.
    152.79 MB
    "Usually" injector seals. I'd start there.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Wodonga
    Is it dangerous to drive like this?
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by gruntfuttock View Post
    People do. I'd fix it sooner rather than later though. Damage will occur.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jun 2013
    Universe A
    Bad for the crank and big ends and mains.
    Normanhurst, NSW
    And possibility of engine runaway with that much diesel in your sump!
    I wouldn't be driving it at all until injector seals were done.
    Roger
    Wodonga
    Thanks for the advice. I am in Forster and need to drive back to wodonga. So I’ll drop the oil and put fresh in. Will that be sufficient for 3 days?
    Sep 2010
    The Hills.
    152.79 MB
    I would think so.... But don't quote me. Thing is, the oil will be diluted and thus less effective, and if it gets too full other problems happen. I would keep an eye on it over those three days.
    Remember, it has probably been this way for at least a little while.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Nov 2014
    Nirvana near Albany W.A.
    Generally, the first thing to "let go" will be the turbo, as undiluted oil to that is pretty important.
    Definitely, as you say, change the oil, and keep an eye on it for the trip home.
    The old method suggested by Rick 130 of the droplet on the business card works well ( rainbow around the droplet means diesel )
    I got called in to see one at a local workshop last year that had 21 litres drained out of the sump without having a runaway, surprisingly.
    It was a very clean engine.
    Wodonga
    Thanks to everyone for the replies!
    The oil will be changed tomorrow, I would like to do the filters as well but it seems that there are none available here, but will ring around the shops in the morning just in case of the online store thing has it wrong.
    A big thank you for the oil on the business card trick. I will try that in the morning, thats if we haven’t been blown away during the night.
    Thank you everyone!!
