Results 1 to 4 of 4
Thread: 7 seater. Coils or air?
    May 2015
    Williamstown, Victoria
    I am looking at a couple of D4s on a auction site. The suspension up and down switch, if it is there is obscured by the gear lever. Can I assume that the 7 seater ones had air suspension?
    TIA
    Build date 11th Oct 2003
    LROCV #1410
    Jun 2013
    Universe A
    I don't think you could get a D4 in Aus that DIDN'T have air suspension.
    I believe and have seen D3s with coils, but never a 4.
    Someone can verify, but I think that is correct.
    St Helena,Melbourne
    1.13 MB
    Correct, all 7 seaters have EAS. D4 only came with coils in South Africa i believe.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2014
    Baldivis WA
    No coils on D4 7 or 5 seaters unless private import from the UK.
    External photos can also provide a clue, should be able to see the rear struts and air bags if the angle allows.
