Results 1 to 4 of 4
Thread: Bluetooth OBDII Problems
    Mar 2017
    Armidale, NSW
    Hi all,
    I come here seeking help acknowledging that I know nothing.
    I am having some electrical problems with my D5. It is a massive parasitic draw that flattens the battery within hrs. I have been able to track down eventually to when it occurs but I can not explain it. First the issue.
    It has been diagnosed as the Alternator not shutting down properly and continuing to draw power from the battery. I have been told that it needs to be replaced - still waiting on that one though. The unusual thing is that when I leave the dealers the problem disappears - I am assuming they have done a system reset or something similar. I still can see that the battery is never being fully charged though - they acknowledge that is part of the problem. Anyway - drive out of the dealers go home, turn the car off and the alternator doesn’t draw power. Will continue like that till I do the following. I have been slowly adding things back and doing things to try and find a cause.
    I can see that if I plug in my OBDII reader and drive around nothing happens to the car. Alternator is not triggered after shutdown.
    If I connect to the OBDII reader with my phone and connect to the reader then stop the car the issue reappears. I am using a VEEPEAK bluetooth dongle and the software I am using is Car Scanner ELM OBD2. I do not use the dongle to alter anything just read data - actually purchased it so I could monitor transmission temps while towing. Anyway I select Land Rover and generic OBD2 during setup.
    I have no idea why this could be happening and any help would be appreciated.
    All the best,
    Laurie
    2019 sd6 SE
    2012 SDV6 SE (Son stole it from me)
    May 2003
    On The Road
    Disconnect the dongle, its probably polling the car every couple of minutes..
    I run a Gap tool in my RRS 365 days a year.
    Mar 2017
    Armidale, NSW
    I disconnect it and remove the dongle and it the issue still exists. Like it starts the problem and if a disconnect the battery to do a ECU reset the issue goes away till I use the dongle again.
    Dongle works fine on my other cars and doesn’t cause any issues I am aware of.
    All the best,
    Laurie
    2019 sd6 SE
    Jun 2013
    Universe A
    It's quite possible there's a fault with the dongle.
    It's also quite possible that CarScanner has issued an incompatible request and put the ECU into some kind of loop.
    I would either try changing the dongle or select a different connection profile, I think it has listing specifically for D4, I'd try that one.
    The generic ones are a bit so so.
