Results 1 to 6 of 6
Thread: Lower windscreen seal
    Dec 2023
    Vic
    Hey all,
    Recently picked up a td5 130 and it’s leaking a fair amount around the lower windscreen seal.
    Someone has had a go at siliconing it up.
    Just wondering if it’s better to try and clean it out and replace the seal. Or just go round 2 with silicon?
    Dec 2023
    Vic
    Quote Originally Posted by p38arover;[URL="tel:3217664"
    yeh that’s the seal that’s kaput,
    was curious on what others have done. Replace or just use other sealing methods.
    Jul 2018
    Essendon
    It’s not too bad to replace if you can undo the front headliner easy enough. Then for me it was a &b pillar bolts and the windscreen hinges. I used a seal that came in a blue bag and it was fine/still are after 3ish years
    Quote Originally Posted by Patrick110td5 View Post
    A blue bag sounds like a BritPart item.
    Oct 2007
    Wantabadgery, N.S.W.
    I covered the seal with white Sikaflex. You’d have to get rid of every skerrick of silicone if you wanted to do the same.
    Don.
