the D90 Puma carrier was a 2 pin design.  Not as strong as the front 200/300tdi and Puma 110HD/130 4 pin (not sure what TD5 was and given it had a change over in 2002, could be anything from the parts bin).
To the OP, understanding torque helps with explaining breakages. Torque is a twisting force.  An engine produces torque based on demand.  Driving on flat land the engine produces less torque than when going up hill.  Also weight is the real killer of diffs.  Heavier you are, more torque (twisting force) is generated from the extra resistence from the contact with the ground versus the engine trying to turn the wheels.  Shock loading then also comes into play but not really a problem for a tow vehicle.
To the OP, your comment of symetrical torque bias 50/50 front to rear only happens when the CDL is engaged and that does not account for the left to right bias.  Torque follows the path of greatest resistence.  If 1 tyre has more weight on it or has the highest contact (grip) with the ground, a higher proportion of the engine torque is in the driveline at that wheel.  Torque is constantly moving around the driveline.  for example if you are facing down hill into a left hand bend, the front right will have proportionally the most weight of the 4 tyres and thus the twisting force of torque is temporarily the hightest on that corner.
				MLD
Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
Gone: (Dorothy) MY99 TD5 D110
