Don't forget steering damper, and it's bushes, and also panhard rod bushes.
In my case it was steering damper and bushes(stoopid vacuum pump leak destroyed bushes, and they felt like marshmellows).
I just got a std (Armstrong) damper, being cheap .. and not being sure this would be the issue.
I've also fund that steering wobbles can be caused by worn shock bushes, but the effect is almost always limited to wobbles on medium to large bumps/potholes.
According to RAVE, with track rod, drag link disconnected and ball seal removed .. force needed to swivel the swivels is between 1.16 - 1.46 kgs
