It could be that your hub seal is notsquare??
I had a similar issue and even though I fitted a new stub I fitted another new stub with new hub seal.
Is the reason for you changing to oil lubed wheel is because you have fitted maxi drive type axles and drive flanges??
If not, I’d stick with grease lubed
