Results 1 to 10 of 27
Thread: Ashcroft Stage 2 4HP22, any probs?
    Nov 2014
    Germany
    35.44 MB
    Hello everybody!
    Have to change my Autobox asap. Will order a refurbished from Ashcroft.
    Now, Stage 1 for sure. But what is with Stage 2?
    The only concern I can see it is 15mm longer.
    When I check my gearbox mounts, there should be enough space to cope with this.
    But what is with the propshafts? Will it give me some problems there? Is the front one then to short and the rear one too long?
    My D2 is on a 2“ lift actually, maybe this will it make more worse at the front?
    Or the other way round, is it all the effort worth? Makes it that big difference?
    My D2 sits on 32“ tires, new hybrid turbo from Jose is on the bench and it is most time full laden with camping stuff…
    I am happy for all reviews and reports!
    Sep 2010
    The Hills.
    152.79 MB
    Don't have the answers. But I do have a suggestion: email Dave Ashcroft. He, or someone, will answer. The answer will most likely be brief, but you will get one. Well, that's been my experience.
    dave@ashcroft-transmissions.co.uk
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by Werdenfelser View Post
    Hello everybody!
    Hi
    The ( much ) larger surface area of the "A" clutches are a huge benefit if you are intending to go above around 450 Nm , up to around that figure I usually just fit upgraded forward clutch packs.
    Another benefit of fitting the full ZF24 is that you are future proofing the car in case you do want to run over 450Nm, reliably.
    Don't forget the V8 converter and kit
    You can use a rear shaft from the 4.6 V8 version ( TVB000330 ), or simply get yours shortened.
    As for the front, just a 15mm spacer will be fine for a 50mm lift, such as a DA6339, though 20mm might be better.
    I just finished building one yesterday, for a keeper (D2a)
    99.87 MB
    It really wouldn't surprise me if the propshafts just take up the 15mm, the slip joints shouldn't be that marginal.
    What would surprise me is if you get the extra 15mm out of the gearbox mounts.
    That said, mine has had the 3/4th clutches upgraded to 4HP24 units and that doesnt make it a longer gearbox. That setup has been totally reliable with a ECU/IC/Boost and ATF cooler which is key, but I'm also not pushing the same power as what you're looking at.
    I could be wrong, but I thought if you pushed big torque through an auto it just went into limp mode???
    Slunnie
    Sep 2010
    The Hills.
    152.79 MB
    Interesting point. I think I'd be more concerned by the compression on the rear one than extension of the front. And I wonder if it might relieve some of the stress on the double cardan joint caused by the lift. But I could also be talking through my 18th letter of the alphabet.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Nov 2017
    Quote Originally Posted by Tins View Post
    ....18th letter of the alphabet.
    Nice circumvent.
    Martin
    The secret to happiness is to truly want what you already have
    Oil leak?...Nah, sophisticated anti corrosion system!
    '04 D2a TD5 Manual "Snowy" - Daily
    '04 Def 90 TD5 "Hue" - New toy
    '03 Def 90 TD5 - Son's toy
    '16.5 D4 TDV6 - Gone
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Max Headroom 2.3m View Post
    Nice circumvent.
    It's called learning from experience.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jul 2017
    Victoria
    Slap a r380 and run 600nm plus without the common issues with the auto
    03 D2a Manual Td5 Modified, Ashcroft lockers F&R, Ashcroft R380,Atb lt230, Ashcroft Rear axles, AS manual IC, AS exhuast manifold, AS Coolant bottle, 3inch exhaust, alive GTB550 VGT, billies 7100s, 3inch lift, 4inch staino snorkel, 35s beadlocked
    Nov 2014
    If you're pushing big torque you want the front shaft to be as "engaged" as it can.
    Unless you want to only ever drive on flat roads with no bumps and you're happy to jack the rear diff away from the transfer case just to fit the rear TD5 disco shaft, then I'd suggest using the shaft that Land Rover themselves used or shortening it.
    If you were to take a look under your D2, you'd see that the chassis side is slotted.... surprise!!
    No, what you probably have had someone fit is the Intermediate ONE WAY clutch from the 24, there are no frictions involved.
    Nearly Every manufacturer that wants to push big torque will opt for an auto box.
    In the case of the electronic ZF 22 4 speeds, a good tuner can mitigate this to an extent.
    At least you're consistent
    99.87 MB
    Quote Originally Posted by discorevy View Post
    The slip joint stays on the splines and fully engaged, I'm not talking about having it all hanging out - its 15mm. The suspension pivots around points very close to the transfer outputs, so there isn't much change in length from the suspension cycling. I also would/did step the shaft up to at least 1310 rather than factory.
    I did, and the slotting wont give enough, at least on mine.
    Thats not what I said or meant at all.
    When I was doing all of this the ZF 22 limited the torque, I don't recall the value, maybe 400Nm, it would send the autos into limp mode and need a restart to clear it. The tuners would run the ECU's up to this and on a cold day when you put your foot down it would then go into limp. Oh well, thats great if they've overcome that limitation.
    I'm really not sure what you're being like that for but great if that makes you feel better for yourself.
    Slunnie
