Pricewise cant beat Kings.
I have one on an Amarok, been up and down the 3 N/S tracks in SA and twice across the Simpson, no probs , check all the assy nuts and bolts regularly.
Depending which rack you buy gives you many options for assembly and relatively easy to change how you use it at a later date.
Regardless of how good you are you cannot assemble in 2hrs as instructional video shows. Mine has 64 nuts/washers/bolts....all stainless steel, but if you can loose assemble everything as you want it , you still wont do it in 2 hr.
good luck in your search
