Results 1 to 6 of 6
Thread: Making a USB-to-ECU piggyback module lead (non-LR)
    Jan 2008
    Melbourne, Vic., Oz
    Wanting to pick the brains of the electronically astute...
    I have a KTM RC390 motorcycle that I have fitted an ECU piggy-back module to. All working well BUT to buy the "factory" USB-to-module lead for diagnostics is an eye-watering $95.... Wanting to make my own lead.
    It terminates on the module to a Sumitomo 4-pin MT090 plug:
    And of course, the other end is a USB-A, which has to follow standard conventions:
    Have bought the unterminated versions of each.
    My question is: can I use a multimeter connected to the MT090 (unterminated, while connected to the module) to determine which leads are the +5V & ground, compared to the +Data / -Data? I can't figure out how to differentiate between the ground and the -D wire. I obviously don't want to connect the +5V to the +D or -D and fry the module...
    Thanks in advance!
    St Helena,Melbourne
    4.28 MB
    I have a triumph Daytona T595 and program the original ECU using an app called Tumeecu and VAG type USB obd cable. This app also works with ktms I believe.
    No need for an additional ECU or cable.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2008
    Melbourne, Vic., Oz
    Thanks, but I need to make the lead - need to use some specific PC software which relies on a USB connection...
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by skidrov View Post
    But will the lead work as there are probably differing protocols involved.
    1974 VW Kombi bus
    Jan 2008
    Melbourne, Vic., Oz
    Yes, as it needs to come back to a standard USB PC protocol/pin-out.
    It's "simply" Making a USB-to-ECU piggyback module lead (non-LR) a matter of correctly identifying the 5V power side v the 3V data side. With the thing I am unsure of being the differentiation between ground and -D.
    Mar 2018
    Perth (near Malaga)
    If I was trying to pick Gnd from D- I'd probe around with my meter in both Ohms and Diode Check mode. Put the negative on the chassis and poke around with the positive probe. On any meter I've used recently they are both well current limited. D- will either be floating or have clamps on it (should have a hard clamp at about 0.6V over 3.3V). Gnd will just be a hard Gnd.
