Results 1 to 6 of 6
Thread: Rear Prop Shaft Lengths
    Sep 2018
    Travancore
    HI guys
    NOT a defender owner but have a D2 that I am fitting a 8HP to the TD5, it would appear that I have to move the LT230 back (unsure how much yet) but thought it would great to know the alternative length tail shafts that could be potentially used if necessary.
    Does anyone have a list of such?
    Arty
    2004 Discovery 2a TD5 Auto Aspen Green AKA Robin
    2000 Discovery 2 TD5 Auto Alverston Red AKA Edward
    1997 Discovery 1 TDi Manual White - Gone but not forgotten
    1994 Discovery 1 V8 Auto - Gone once it consumed half the worlds resource of oil
    Sep 2018
    Travancore
    Been doing a bit of research, sure within all this I will find something!
    Series 1:
    86, 88, 107, 109 Front: 654mm / 23.812"
    86 & 88 Rear: 554mm / 21.812"
    107 & 109 Rear: 1087mm / 42.812"
    Series 3:
    4cyl Front - 604.8 mm / 23.812"
    6cyl Front - 693.7 mm / 27.312"
    88" Rear - 554.0 mm / 21.812"
    109" 4cyl Rear - 1042.9 mm / 41.062"
    109" 6cyl Rear - 955.7 mm / 37.625"
    110 300TDi Commercial 1997:
    Front: 635mm
    Rear: 1100mm
    Range Rover V8 4-speed Auto 1986:
    Front: 610mm
    Rear 890mm
    Series 1 80"
    rear - 40cm compressed, 45cm extended
    989 110 rear propshaft.
    1015mm to 1070mm
    d5 110 w/ R380 & LT230
    rear 1110mm,
    Tdi Discovery
    rear 887mm's long.
    Also
    Defender 200 front 685
    Def 200 rr 667
    Def 300 fr 637
    Def 300 Rr 720
    110 Puma
    rear is 1070mm closed length.
    200tdi 90:
    fully extended: 27.75"
    fully compressed: 25.5"
    https://www.southwalesprops.co.uk/propshaft/vehicles/landrover/landrover_defender.htm
    https://www.southwalesprops.co.uk/propshaft/vehicles/landrover/landrover_discovery_mk1.htm
    https://www.southwalesprops.co.uk/propshaft/vehicles/landrover/landrover_discovery_mk2.htm
    VEH-G-189-23-LandRover-110-all-types-Configuration-Inspection-Maintenance-and-Repair-of-Propshaf.pdf
    https://www.devon4x4.com/off-road-store/drivetrain-and-axles/propshafts.html
    https://www.ep90.com/propshafts-ujs.html
    Nov 2014
    Nirvana near Albany W.A.
    I usually get them shortened, just picked one up today, 18mm shorter to suit a TD5 Disco with ZF 24 box and thicker rotoflex, my local engineers do a good job.
    Is that not an option?
    Apr 2016
    Balancing joint in Preston on Chiefly Drive, on the corner of Fink St.
    Balancing Services.
    I had the front prop in my RRC straightened and balanced by this mob. Did a good job.
    Was, like, a gazillion years ago tho.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Sep 2018
    Travancore
    Quote Originally Posted by discorevy View Post
    Quote Originally Posted by AK83 View Post
    Balancing Services.
    Sure is an option, what sort of pricing and turnaround for this???
    Have to make some custom pipes up for the cooler so it wont be a single day changeover but this of course means that if it is a quick turnaound of around a day. Can of course drive it as a front wheel drive for day or so...
    Nov 2014
    Quote Originally Posted by RRT View Post
    Was $160 / 2 days turnaround, but that depends on how busy they were.
    You could also get one from a wrecker (late D1 will work as well) or use the other disco in your sig if they would take a while.
