Results 1 to 9 of 9
Thread: 3 way fridge fan kit.
    St Helena,Melbourne
    4.28 MB
    With the temps in the high 30's on my recent camping trip the dometic 3 way struggled to keep a decent temperature, i have seen some fan kits advertised but not about to spend over $100 for a couple of PC fans and a bit of wire.
    Anyone done this to their fridge ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    I did to my Engel when I fitted a digital temp controller. The fans were old PC fans I had.
    See this thread: Has anyone fitted temp control unit to an Engel?
    St Helena,Melbourne
    4.28 MB
    Something similar to what I will do,have read about using a normally open thermostat switch to turn the fans on and off.
    1974 VW Kombi bus
    Aug 2010
    Sunbury, VIC
    Yep, used 2 cheap PC fans on my old Franklin when I ran a 3 way. Worked well and got a few extra degrees out of it but still struggled when the temps were high and you really want a cold beer so I ultimately ditched the 3 way and put an Engel in like this - Engel Upright Fridge 95 Litre - AC and DC - Engel Australia
    Expensive yes but worth every cent. Draws 3 amps when running and a 100ah battery and a couple hundred watts of solar keeps it happy.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Homestar View Post
    I want something like that for the OKA, but at $1650 maybe I'll stick one of my house fridges in there. Course, I'd have to spend more than that on batts and a huge inverter.... This living off grid **** is expensive.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Tins View Post
    600 watts of solar, 300AH of lithium and a 3000 watt inverter - that’s what will comfortably run my coffee machine and leave enough in reserve for 3 fridges, lights, chargers etc. 3 way fridge fan kit.
    If you have the room overkill the solar - it’s cheap now so fill every available spot and have a couple of hundred watts as a portable setup for when you’re camped in the shade. I have a 20 metre lead and don’t use a charge controller on the portable panel, just run its straight into the main victron solar charge controller.
    Brisbane,some of the time.
    I wouldn't waste the time or money,you are much better off putting the money towards replacing it with a compressor fridge,Bushman,Engle,whatever.
    They are way more efficient than a 3 way.
    St Helena,Melbourne
    4.28 MB
    I use my 50ltr waeco for drinks so a couple of extra degrees cooler will be fine for the food but i was considering a 12V compressor fridge option, i have enough battery capacity and solar.
    1974 VW Kombi bus
    St Helena,Melbourne
    4.28 MB
    I disagree, 3 ways have their place and work quite well and efficiently on gas just struggle a bit in high temps which the fans should help with.
    1974 VW Kombi bus
