Results 1 to 10 of 19
Thread: Can I co-locate a diesel heater with a gas hot water system?
    Jun 2008
    Drouin East, Vic
    We've bought a new-to-us Trayon camper to replace the one that was destroyed in an accident last month and I am wanting to transfer the diesel heater that I installed in the old one, across to the new one. I wasn't 100% happy with the location that I installed it in previously, it was under the cabinet where we store most of our food for a trip and the heat from the ducting and the exhaust was heating up the food cabinet.
    The Trayon has a Truma gas hot water heater in it's own cabinet and I think there would be room in that cabinet to install the diesel heater. I don't know if this would be a safe idea or not? We use the hot water system all the time and the diesel heater occasionally. Certainly there would be times we would want to run them simultaneously.
    St Helena,Melbourne
    4.28 MB
    To me it would make sense to locate them together, my only concern would be if there was a gas leak then starting the diesel heater might ignite it.
    Bit of a what if scenario but the only downside i could think of.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2008
    Drouin East, Vic
    Yes I've decided to locate the heater in the same cabinet with the HWS, I was concerned about the heater igniting any gas leak but if there was a gas leak the HWS would ignite it anyway. Probably put a floor vent in the cabinet.
    Sep 2010
    The Hills.
    152.79 MB
    LPG is heavier than air, so I'd say a vent is a must. Still, if you have a gas leak then the diesel heater would be the least of your worries. Or one of them. You could stick something like this in there. That one is mains powered, but I reckon there'll be 12 volt ones around.
    I'm interested in how you do this. My OKA has a diesel heater located in the cab. Never been happy with that arrangement and also want hot water. These look good, if a little pricey. But maybe getting rid of the gas bottle altogether isn't such a bad idea.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jun 2008
    Drouin East, Vic
    Quote Originally Posted by Tins View Post
    That diesel HWS is pretty pricey, but so is the Truma gas HWS that we currently have, around $950. The posh-pack Trayon campers come with a diesel heater that does both the hot water and the room heating, Apparently they are not available for private purchase as Trayon have some kind of licensing arrangement on them.
    There are plenty of 12v gas sniffers on the market between about $60 and $200, but as mentioned there is already an ignition source in the cabinet if there were a gas leak. I'll probably stick with putting a vent in the floor of the cabinet. Or maybe in the door like the gas bottle cabinet. One complication compared to where I had the heater mounted before is that I'll need to route the diesel line from the RHF to the LHR of the camper; the previous arrangement had the heater in the adjacent locker to the fuel tank. Not an insurmountable problem.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by POD View Post
    Or give it its own tank if you have the room. They don't use much.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    You seen these?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jun 2008
    Drouin East, Vic
    It has it's own tank, i.e. a 5L jerry-can type container that lives in the locker with the gas cylinder. I think I'll re-mount it in the same place, it has the convenience of being on the bowser side of the Defender. I already have a boatload of the small-diameter plastic tubing for it. And yes, they are very economical to run.
    Jun 2008
    Drouin East, Vic
    You seen these?
    That's interesting. Trayon promote theirs as though it were the only show in town. There's a big advantage to the gas HWS and diesel heater that I already have though; I already have them! We run a gas stove too (with the same advantage) so it's no extra hassle to have the gas cylinder. The gas lasts ages, too.
    Sep 2010
    The Hills.
    152.79 MB
    I hear you!
    I have two gas stoves, one in and one out. I like to cook on a fire or coals, but putting the kettle on, well....
    I don't have hot water though. Decisions, decisions.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
