 Master
						Supporter
						Master
						SupporterHello Everyone.
My D3 Sunroof is starting to leak. I replaced the drains 2 years ago and recently tested again and its not them. A small amount of water is sitting up behind the head lining and running forward when I brake. Ive checked the drains in the drip tray and they look clear.
I think the glass seal is allowing water in. I can hear air coming in when I am at 100kmh. I believe the glass seal is welded to the glass. I've priced a new glass from land rover and its very high. Does anyone know where to try to repair the seal or find a cheap option to replace glass and seal? RL Parts in Florida advertises the glass for US 395. Surely I can find one in Australia for reasonable money.
Grateful for your thoughts.
Have you checked the rear drains ? I took the glass panel out and cleaned and lubricated the seal after clearing the rear drains and some debris that was caught in the tracks, i had water pooling in the rear that would rush to the front and overflow the drip tray.
The seal will never be 100% sealed and any water that gets passed with drain away if the drainage tubes are clear.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
