Thread: Researching history of a 1955 Series 1
    Mar 2024
    Geurie NSW, Australia
    Hello,
    Apologies in advance, I'm a complete novice at posting in this forum. I think I may have posted this in the wrong location initially.
    We are interested in learning as much history as we can about a 1955 Series 1 we are taking on as a project. So far we have the chassis number (the engine number is yet to be located, but we do have at least 30 years of crud to clean off first...).
    We have decoded the chassis number but we are wondering if there is a way of using that number to confirm when it was originally dispatched (presumably from Grenville Motors) and the original dealership it was purchased through? We know some of the vehicle history and who the original owner was and its likely it was originally purchased in Coonamble NSW via Permewan Wright (but Dubbo, Gilgandra and Coonabarabran remain possibilities).
    We are keen to put together and document as many pieces of the puzzle as we can.
    The chassis no is 57661733.
    Last edited by Bitzer55; 22nd March 2024 at 09:48 AM. Reason: Font size seems too big, still learning how to use this platform :-)
    Back down the hill.
    You're in the right area, I'm sure you will get some knowledgeable information soon.
    JDNSW's Avatar
    Well, for what it is worth, it is clearly not the one I owned in the early sixties - that was ex SMHEA.
    Mar 2017
    Tamworth NSW
    Quote Originally Posted by Bitzer55 View Post
    Hello,
    Sorry, my Grenville Motors ledger info only goes as far as 57660800. Someone may have later pages. The engine number should be stamped vertically on the exhaust manifold machined face on the block immediately in front of the exhaust manifold. (tiny number stamp used) My son has an earlier 1955 model CKD RHD 107 chassis 30 ? I think. Engine block casting dated 7/54 and all Lucas items dated 8/54, so a very early '55 model. These date stamps can be helpful. Yours is a later '55 107. Is there any weight/owners name on the RH front wing still? That info can also be very helpful if still visible. We had great service for engine parts from Cox & Turner in the UK and JP Pistons in AUS. These '55 spreadbore engines have the 11/16" piston pins whereas the '56 on engines have the 7/8" pins. We found out the hard way.
    Anybody need a set +0.030" 7/8" pin piston assemblies? 5380
    Mar 2024
    Quote Originally Posted by 5380 View Post
    Thanks for your response and advice
    Yes, the original owner and property is printed on the side and we have been able to turn up some of their history via Trove and Ancestry so far. Will keep hunting!
    Mar 2017
    Tamworth NSW
    Good hunting! I find the search for this sort of info fascinating! If only they could talk! I was lucky enough to get to speak to a retired farm worker who remembers driving my 80" around the foothills of the Barrington Tops in the late 1950s and early 1960s when he worked for Belltrees Station. It got a bit tired after 44 years and 74,000 miles and was parked under the woolshed at Belltrees from where I rescued it in 1998. Apparently it ran out of brakes and gave someone a big fright. When I got it home and checked out the brakes, I found that the linings and drums were so worn that one of the front wheel cylinder pistons popped out of the cylinder when the circular band of the drum parted comany with the flat mounting face! I'd never seen a 2 piece drum before that. 5380
    Mar 2024
    Finally picked up the new family member yesterday and located the engine number (thanks for the location tip, we had previously been scraping dirt off the wrong face on the engine block). Engine number is 57115902.
    I'll figure out how to upload a couple of photos later.
    JDNSW's Avatar
    I live only about an hour away and would appreciate the opportunity to have a look at it some time.
    Mar 2024
    Smile
    I'm sure we can organise that sometime
    Mar 2017
    Tamworth NSW
    Whoops! I misread your chassis number. A 5766 chassis number is of course a 1955 RHD Export CKD 86". A 1955 RHD Export CKD 107" chassis number starts with 5776.
