Results 1 to 8 of 8
Thread: 6 cylinder radio suppressed distributor?
    Denmark WA
    Hi All,
    Anyone got any thoughts?
    Not an add from me!
    There’s a seemingly suppressed 6cyl distributor. That’s not from a lightweight as advertised. Australian SIII radio vehicle?
    SERIES LAND ROVER MILITARY LIGHTWEIGHT PARTS: Dizzy-Coils-Leads-Plugs | Auto Body parts | Gumtree Australia Geelong City - Grovedale | 1315098133
    1974 Military Lightweight Landy --- Some dementia at 50 years old
    2000 Disco series 2 now sadly moved on!
    No5 Trailer joined the fold... Awaiting graduation to road licensed!
    2021 Mazda BT50 or is that DMax?
    Sep 2010
    The Hills.
    152.79 MB
    Dunno but it's gotta be worth twenty bucks.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Denmark WA
    Yep the lightweight ones are worth $$$$ in the UK.
    Sep 2010
    The Hills.
    152.79 MB
    If you burrow into the ad a little more I think you'll find he has a bit of stuff. Tipping you won't get that dizzy for 20 bucks....
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Denmark WA
    Yeah the other adds have more realistic prices…
    East-South-East Girt-By-Sea
    1.20 MB
    The six cylinder SIII FFR did have a suppressed Bosch ignition system, so its probably from one of them. But unlike the Brit lightweights and FFRs which had a CAV fully shielded dizzy including leads and shielded spark plugs.
    The Bosch dizzy in the FFR was pretty much the same as the Bosch in the GS (civvy SIII had a Lucas dizzy) The actual suppressor in the Bosch dizzy was on the rotor button in the contact track between the centre contact and the tip was a little resistor. It was also a common fault, the resistor would fail and the spark no longer passed to the plug leads. You needed to replace the rotor button or on one field repair of a mates SIII I soldered the gap where the resistor once was.
    The suppressed distributors also had shielded dizzy cap, basically it was coated in an aluminum membrane the leads also had metal shrouds over the spark plug connectors.
    Denmark WA
    Thanks for that! And if you take a look he has the CAV ones too… My lightweight used to have one before someone did a 12v conversion on it…
    Back down the hill.
    If you buy anything from Gumtree, use PayPal.
