 Originally Posted by
tibbsy
BTW - should i get a shock when adjusting the distributor?
 No, definitely not.. Check you have all your earth leads connected properly ( you may have disconnected one or more taking the head off) and also check the condensor. Does your car have a ballast resistor?
The fuel issue, looks more like a stuck valve to me, or a timing misfire. You say the valves and rockers are moving when you turn it by hand? Go over the clearances again. I reckon you might have an inlet too tight.
Thought for a second you had leads one and two reversed, but then I remembered Series dizzies rotate anti clockwise.... don't they? But, easiest check, are the leads all in the right spots? I see you labelled them, so they probably are, but it's a very easy mistake to make.
Just my two bob's.
Good luck, let us know how it goes.
				JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto:                Tins
1994 D1 300TDi Manual:        Dave
1980 SIII Petrol Tray:             Doris
OKApotamus #74
Nanocom, D2 TD5 only.
